185/70R14 Tire recommendations
Noahs944
PostPosted: Mon Dec 21, 2015 2:32 pm    Post subject: 185/70R14 Tire recommendations Reply with quote
I *think* my stock 14" 1978 wheels require the size listed above. Can anyone recommend a sticky DOT summer track tire? All I seem to find are winter tires...
PostPosted: Mon Dec 21, 2015 3:04 pm    Post subject: Reply with quote
Good luck with that.
It's not really summer tire buying season.
Also that size is more commonly used for snow tires and basic passenger car tires.
You're better off buying a set of 15" alloy wheels to use with sticky tires and keep the 14's for the winter.
PostPosted: Mon Dec 21, 2015 4:31 pm    Post subject: Reply with quote
Try searching for 195/60s. That's what was on my car when I bought it and they do fine.
Noahs944
PostPosted: Mon Dec 21, 2015 10:37 pm    Post subject: Reply with quote
I already have a problem with too many tires and wheels that don't match for my cars, and have spent too much on a 924 that isn't on the road... this car hasn't proven it self to me yet... once it proves it's worth, then we'll chat about gifts
Noahs944
PostPosted: Mon Dec 21, 2015 10:39 pm    Post subject: Reply with quote
THANK YOU for the great advice. Check these babies out: http://www.1010tires.com/Tires/Reviews/Falken/AZENIS+RT-615K
Also, a comparison (I will have to look up and see what size actually came on the '78 back in the day): https://tiresize.com/comparison/
Kenodog
PostPosted: Tue Dec 22, 2015 12:09 am    Post subject: Reply with quote
Go 5-lug set up and be done with it. Not a lot of money considering the benefits and waaaay more tire/wheel choices.
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Tue Dec 22, 2015 1:32 am    Post subject: Reply with quote
Leigh
Really, with 5x130 you are locked in to porsche wheels. 4x108 has way more wheels to chose from, new and second hand, at least over here:)
Kenodog
PostPosted: Tue Dec 22, 2015 2:40 am    Post subject: Reply with quote
Yes, but for the usual $300 for a complete 5-lug set-up you get - bigger sway bars, rear discs, more tire choices (15"&16") and the option for about 5 different Porsche rim choices. Very little cash investment for a major suspension / wheel upgrade. Mi dos centavos.
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
Noahs944
PostPosted: Thu Dec 24, 2015 10:39 am    Post subject: Reply with quote
Not a bad idea & I see where you are going with the suggestion. Maybe down the road. But my car has newer brakes, struts & alignment.... and it was good enuff for Porsche & VW at the time, so it might be good enuff for me.
Brockoli
PostPosted: Fri Dec 25, 2015 1:35 am    Post subject: Reply with quote
I put yokohama avs es100 on my '79 in the past. They were 205/60R14 I think. Pretty sticky tire but never got those tires to the track. They had more than enough grip for street driving. I dont think they make that tire anymore but 205 wide had more options at that time.
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
25% of a '87 944 Chumpcar http://straightpipe.ca/forums/showthread.php?t=2454
'79 924 Sebring Edition(Sitting)
Noahs944
PostPosted: Fri Dec 25, 2015 2:11 am    Post subject: Reply with quote
Interesting Brock. No problems with rubbing. I assume factory suspension height? I wonder what would be better, 205 or 190. Wider contact patch with the 205 but would it exhibit more roll when corner? With what you know now, would you make the same call on the size?
Kind of a question I've been asking myself with my 944 since I have 16"x 7 & 8 staggered. Too many options and I don't have the experience to rely on to make the best decision.
Brockoli
PostPosted: Fri Dec 25, 2015 2:48 am    Post subject: Reply with quote
it was lowered slightly using weltmeister springs and adjusting the rear with the eccentric bolt. I did have a bit of rubbing when at full steering lock. I think it was the tire on the sway bar....but that car was in an accident before I got it so who knows how straight it actually was.
I didnt notice much tire roll but I never drove that car on track so didnt really lean on those tires that much. I did like the meaty look of those tires on a 6" rim (as meaty as a 205 can be lol)
Ive never had any other 14" tires so I have nothing to compare too.
When I put 225 and 245 on my current car it was way too much tire. On track it was boring and on parts of the track I was now WOT and not gaining any speed. Quicker lap times that day but not as much fun since the car wasnt wiggling around at all
PostPosted: Fri Dec 25, 2015 2:24 pm    Post subject: Reply with quote
I also ran 205/60/14s in the past. Not a lot of people make that size anymore. I really liked them on my 77.
vdub6v
PostPosted: Tue Apr 27, 2021 2:03 am    Post subject: Reply with quote
Anyone running 205/70R14 on their stock 14" rims?
I really like the look of the white lettering on the BFGoodrich Radial T/A but they don't offer a 185/70R14
