Phone dial wheels
nightrunner68667
PostPosted: Wed May 04, 2016 7:48 pm    Post subject: Phone dial wheels Reply with quote
What should a set of phone dial wheels with new tires cost?
Just ballpark number??
Thanks
Always wanting to learn.
PostPosted: Wed May 04, 2016 9:21 pm    Post subject: Reply with quote
6Jx15 phone dials are plentiful and cheap. I wouldn't pay more than $200-$400 for a set, depending on condition. The larger versions go for a bit more.
michaelodonnell123
PostPosted: Wed May 04, 2016 10:42 pm    Post subject: Reply with quote
Ideola is spot on right. Check Craigslist as well as eBay for a set. If you find a set that needs a little facelift, you can easily use some Dupli-color paint kit to make them look great again.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
PostPosted: Wed May 04, 2016 11:22 pm    Post subject: Reply with quote
If you're patient, you can do great. There was just a set on Craigslist here, 15x7 with 80% BFG tires for $200.
nightrunner68667
PostPosted: Wed May 04, 2016 11:34 pm    Post subject: Reply with quote
The reason I am asking, I am looking at buying a 1987 924s parts car, it us complete except for the dash, $500.00
PostPosted: Wed May 04, 2016 11:39 pm    Post subject: Reply with quote
Race car!
brian19600
PostPosted: Thu May 05, 2016 12:41 am    Post subject: Reply with quote
If you're planning on putting them on your car, make sure the offset is correct.
I thought the 924 takes early offset phone dials. Someone else with more experience needs to confirm what I'm saying though.
PostPosted: Thu May 05, 2016 12:49 am    Post subject: Reply with quote
In 911/944 lingo, the toofah takes "late" offset (around 52mm).
brian19600
PostPosted: Thu May 05, 2016 1:05 am    Post subject: Reply with quote
...and the 924s takes the early offset?
PostPosted: Thu May 05, 2016 3:28 am    Post subject: Reply with quote
No.
Toofah = 924
Our cars use a *high* offset of 50mm-60mm, which is the same as the 87-onward 944/951. So you need phonies with the 52mm offset.
XLR8
PostPosted: Thu May 05, 2016 7:02 am    Post subject: Reply with quote
Toofah = 924
Does that apply to 4 stud cars as well? I am really finding it hard to ID the OEM offset and width of the wheels on those.
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
brian19600
PostPosted: Thu May 05, 2016 10:16 am    Post subject: Reply with quote
So all 924's have to use late offset.....
like this is showing:
https://web.archive.org/web/20130911041327/http://www.cantonia.com/wheel_offset.html
and this:
http://members.rennlist.org/951_racerx/WheelsFAQ-StockSizes.html
PostPosted: Thu May 05, 2016 11:01 am    Post subject: Reply with quote
and this:
All 924's with 5-lug (including 924 NA, 931, and 924S) use *high* offset wheels. Yes.
I believe the offset on the 4-lug wheels is ~33mm. I will check the spiderwebs I have in the shop to see if they're marked.
XLR8
PostPosted: Thu May 05, 2016 11:46 am    Post subject: Reply with quote
That makes sense as the A-arms are longer, but the wheels need to locate around the same track as the 4 stud (I am assuming).
Dan, that would be great.
I have started a "definitive" offset thread to act as the reference. Your input will greatly assist.
'81 Porsche 924 NA
