Amount of spark advance from idle.
procyon
PostPosted: Sat Sep 12, 2015 10:28 am    Post subject: Amount of spark advance from idle. Reply with quote
First post on this remarkable forum. I have a 1981 NA 924 that I am attempting to sort out. Through a slight misadventure I managed to break the connector to the Hall sensor on the distributor. I was unable to remove the metal rotor on the distributor shaft while it was in the car, so I pulled the unit while the system was at TDC. I was still unable to remove the metal rotor but I was able to repair the plug. So it is back in the car and the car is running again, finally. (But that is another story) With the timing light at idle the mark on the cam is very close to the pointer, so that is good. My question is this; when I increase the revs above idle while using the timing light shouldn't the timing mark on the cam advance a reasonable amount? When I increase the revs the mark moves about 1/2" or 12 mm. Wouldn't 35 degrees of spark advance move the mark more than that?
When the distributor cap is off you can manually move the rotor a small amount so it would seem the mechanical advance works, and if you apply vacuum to the diaphragm the rotor move, so it would seem the vacuum advance works.
The car runs like crap because there are fuel problems as well.
Any thoughts on this?
1980 924 N/A ( 5 bolt discs and better paint) MS II V3.57
2003 Subaru Baja
2021 Maxda CX-30
PostPosted: Sat Sep 12, 2015 3:47 pm    Post subject: Reply with quote
Cam pulley rotates once for every two crank rotations. You should be using the TDC mark on the crank pulley or flywheel.
Also, pop for an adjustable timing light, so you can see how many degrees it is actually advancing.
procyon
PostPosted: Sun Sep 13, 2015 12:56 am    Post subject: Reply with quote
A buddy of mine has an adjustable light and I will use it this weekend.
I don't see how you can use the mark on the flywheel, I can get the timing light to shine on it or I can see the mark window. I can't seem to do both at the same time. We will see if his light works better than mine.
2003 Subaru Baja
2021 Maxda CX-30
PostPosted: Sun Sep 13, 2015 1:27 am    Post subject: Reply with quote
procyon wrote:
I don't see how you can use the mark on the flywheel.
It is moderately inconvenient.
