924 n/a cold start issues.
RobertN
PostPosted: Sun May 17, 2015 4:26 am    Post subject: 924 n/a cold start issues. Reply with quote
Hi, fitted new plugs air filter and HT leads. Still same issue when cold, it takes a few cranks fires and stops a couple of times and then with a little extra help on the throttle initially to get her fired up she starts but idles lumpy until warm after 1 minute or so! After a run she runs brill and starts on the button. Can anyone help with the cold start please?
Thanks.
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
Ozzie
PostPosted: Sun May 17, 2015 9:03 am    Post subject: Reply with quote
hot idle should be about 900rpm
Sounds like the AAV could be faulty
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Sun May 17, 2015 1:40 pm    Post subject: Reply with quote
+1
check your aav and csv are getting 12v,
if you want to pull the hose from the aav you can check the air hole is open at cold temps... it closes when warm...
It's possible its gummed up too... or the hoses around it...
RobertN
PostPosted: Sun May 17, 2015 5:13 pm    Post subject: Reply with quote
Idle is around 850/900. Wil check cold start valve for voltage.
Aav?
Robert.
jason c
PostPosted: Sun May 17, 2015 6:45 pm    Post subject: Reply with quote
RobertN wrote:
Aav?
Auxiliary air valve
PostPosted: Sun May 17, 2015 7:04 pm    Post subject: Reply with quote
there's a funny Porsche name for everything, it's what supplies extra air for the engine at cold starts, has a rotating disc that starts with an opening and closes after a minute or so... powered by the same circuit as the csv
RobertN
PostPosted: Sun May 17, 2015 11:04 pm    Post subject: Reply with quote
Thanks guys. I understand the process now. Thermo TS for csv operation and csv and AAV work like a " choke " system so to speak?
I'll check all my hoses etc,
Is there a way to check all 3 with voltmeter/ ohmmeter?
Robert.
PostPosted: Sun May 17, 2015 11:17 pm    Post subject: Reply with quote
unplug the aav and apply a multimeter to the coonector looking for 12v at ignition on,
A better test for the csv is to unbolt it from the manifold with it still connected to fuel and electrics spray it into a glass drink bottle whilst cranking over the engine, it only runs for about 8 secs approx, this will tell you if the tts is working and let you monitor the spray pattern for the csv
RobertN
PostPosted: Mon May 18, 2015 2:53 am    Post subject: Reply with quote
Hey guys. 12.6v at AAV connector on crank, but only 10.5 at csv blue connector on crank?? Haven't disconnected csv to test, but shouldn't there be at least 12v? I did notice when checking hoses etc a rubber bung at the bottom of the air flow sensor unit which had split, so I removed it and taped it up and re-installed it!!
Starts better after a few cranks and spluttering she fired up! but still a but lumpy for around a minute. After 1 minute running I switched off and back on again and she fired up immediately, should I just leave it or should she start better than this from cold?
Robert.
Ozzie
PostPosted: Mon May 18, 2015 6:54 am    Post subject: Reply with quote
starting straight up usually means the CSV is OK.
lumpy at cold could be the AAV keeping the revs too low or the WUR not working properly.
I suspect the AAV needs a removal and clean.
RobertN
PostPosted: Mon May 18, 2015 7:23 am    Post subject: Reply with quote
Yes Ozzie, revs are low at cold idle around 650-750 ish, then climbs to around 900 after a while. I'll pull the AAV and test. I read you put it in fridge for an hour in a bag and then check the opening and then apply 12v for about 5 mins and watch the regulator to see if it closes?
You mention the WUR is that the same as the csv?
Robert.
Ozzie
PostPosted: Mon May 18, 2015 5:37 pm    Post subject: Reply with quote
Warm Up Regulator is also Control Pressure Regulator and alters the control pressure as it warms up to lean the mixture.
Cold start valve squirts a pile of fuel in only when cranking.
chris79
PostPosted: Tue May 19, 2015 12:56 am    Post subject: Reply with quote
I have same problem of cold start, but because I replaced wur with pressure regulator set 3.4 bar (my wur is restoring).
I have to try for about 1 minute before start engine.
I have always to set control pressure about 1 bar to start engine ?
Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro
PostPosted: Tue May 19, 2015 2:08 am    Post subject: Reply with quote
I'd recommend a CIS pressure test to make sure the WUR is dropping the control pressure when its cold like it should and then slowly raising it while its warming up...
Mine seems to start best when its either really cold (10-45F) or warmed up, Starts like a champ, It's in the 70's-80's here now and it seems to start and idle a bit low at these temps for a few seconds but it starts almost instantly in any condition...
I'm very impressed at how well the CIS is able to deal with cold start conditions especially real COLD starts..
PostPosted: Tue May 19, 2015 2:18 am    Post subject: Reply with quote
Yeah I bet it would help tremendously to lower the control pressure on start then turn it back up after its warmed up, that is exactly what the WUR automatically does but gradually..
Remember
high control pressure = leaner
low control pressure = richer (like a choke)
your car should be
Control pressure cold (approx. 20° C): 1.3...1.7 bar
Control pressure warm: 3.4...3.8 bar
