Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Sat Apr 25, 2015 4:55 pm Post subject: G31 or 016J gearbox for trackdays ? |
I only drive my 931 on trackday's about once a quarter.
That is why it is hard to get used to the dogleg shift patern, and the dogleg doesn't shift very fast (maybe the synchro's are a bit worn also).
I have a complete 944 (1984) parts car. So I am thinking of converting my 931 to the 016J gearbox.
What do you guy's think, a shame to loose the G31 or go for the easier and faster shifting 944 gearbox ? _________________ 937 trackday car
Posted: Sat Apr 25, 2015 9:46 pm Post subject: |
I've had both, and the G31, a rebuilt one, still shifted hard. Have 931 Audi trannies in both track cars, much better. The 944 tranny has a taller 5th gear, but how often is one in 5th? The 931 might be better off with a taller 5th anyway. Of course, you'll have to swap out the torque tube as well. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Sun Apr 26, 2015 12:16 am Post subject: |
Faster shifting? Are you drag racing?
If you want to bang the gearbox Fast and Furious style, try a Miata. _________________ Toofah King Bad
Posted: Sun Apr 26, 2015 4:32 am Post subject: |
| Rasta Monsta wrote: | Faster shifting? Are you drag racing?
If you want to bang the gearbox Fast and Furious style, try a Miata. |
If I shift form 3 to 2 or 4 to 3 it you have to shift gentle. Maybe me synchros are worn a bit also.
The track in Zandvoort (the Netherlands) has al lost of corners so I am losing a few seconds there. _________________ 937 trackday car
Posted: Sun Apr 26, 2015 4:53 am Post subject: |
Mine(80 931) shifts fine, its just the stupid lever moves hard and its difficult to engage 1st and reverse. Must be them bushings i guess.
The dogleg is much more imediate than the Audi boxes.
Its hard to explain, i have both on two different cars and while both are nice to drive, the Audi one is a bit less connected, the dogleg just shoots off the line as soon as you think letting go of the clutch. _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Sun Apr 26, 2015 6:02 am Post subject: |
Do you really need 2nd on zandvoort? I never use lower than 3rd and our Swedish tracks are small. My g31 works nice on track, changed some syncros and 1st dogring, pretty easy job to do. Changed the bushings+short shifter, makes the shifting extremely tight. Do you any Rev matching on down shifts? _________________ 1980 924 Turbo
Posted: Sun Apr 26, 2015 9:16 am Post subject: |
If his track days are once a quarter, either get used to the G31 and it's slow shifts, or install the Audi tranny and not worry about it. _________________ '83 944 Track car.
