Head Bolts
DZGunner
PostPosted: Mon Mar 09, 2015 7:53 am    Post subject: Head Bolts Reply with quote
Hey guys I'm wondering if the same head bolts from the NA models will work in the turbo'd cars. I'm having a hard time finding a set for the turbo or at least no one is specifying that they are different except for Auto Atlanta, who is showing each bolt to be $7 while for the non turbo its apparently only $1.50 a piece.
I also read how the turbo has a different method for torquing the head bolts so I want to know if im gonna have to dish out the cash or if NA bolts will work. Thanks guys.
1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts)
DZGunner
PostPosted: Mon Mar 09, 2015 1:51 pm    Post subject: Reply with quote
I've found in the online Haynes manual that the change from the 6 point allen bolts to the 12 point was made in 1980, but not all the 80 cars (turbos included im assuming) got the 12 point ones because the factory wanted to use up their supply of the 6 point ones. No one knows anything about the interchangeability on these bolts?
1979 924 Sebring
1977 924
1977 924 (Parts)
emoore924
PostPosted: Tue Mar 10, 2015 2:29 am    Post subject: Reply with quote
same bolts on both the turbo and n/a
PostPosted: Tue Mar 10, 2015 2:36 am    Post subject: Reply with quote
Same bolts. I've only seen the 12-point / triple-square bolts on very early cars. All of the engines I've disassembled except one had the Allen head bolts.
Do not order for Automobile Atlanta. Use EBS, Pelican, or AutoHausAZ.
DZGunner
PostPosted: Tue Mar 10, 2015 3:43 am    Post subject: Reply with quote
I know, I used to order from them for my 928, but stopped shortly after. I use them for part number reference and a visual for parts.
So I can go ahead and get a set of head bolts for an NA engine and just use the turbo torque method?
1979 924 Sebring
1977 924
1977 924 (Parts)
PostPosted: Tue Mar 10, 2015 5:30 am    Post subject: Reply with quote
Yes. Torque method is the same (sequence, three-stage tightening), but the torque values are different.
DZGunner
PostPosted: Tue Mar 10, 2015 6:03 am    Post subject: Reply with quote
What are the values if you don't mind
EDIT: I think I found it, can you confirm this?
http://www.924board.org/viewtopic.php?p=146743&sid=6edd0e4e39612636312c0afa6db19184
1979 924 Sebring
1977 924
1977 924 (Parts)
PostPosted: Tue Mar 10, 2015 6:23 am    Post subject: Reply with quote
If this is an exact transcript from the tech specs booklet (which I don't currently have handy), then YES, it is correct:
Tigger937 wrote:
As taken from Porsche "Technical Specifications" Booklet:
TIGHTENING SPECIFICATIONS - CYLINDER HEAD BOLTS - 924
Tightening sequence for cylinder head
_______________________________
|----8-------4--------2--------6-------10----|
|----x-------x--------x--------x--------x------|
|------------------------------------------------| ---------> Driving Direction
|----9-------5--------1--------3--------7-----|
TIGHTENING SPECIFICATIONS FOR CYLINDER HEAD BOLTS - 924 TURBO
1. Tighten cylinder head bolts in prescribed sequence, in stages, to 40Nm, 80Nm and 110Nm.
2. Retighten cylinder head bolts after at least 60 minutes (to allow for setting of cylinder head). To do so, loosen bolt no. 1 (see tightening sequence) approx. 1/2 a turn and tighten to 110Nm. Repeat this procedure with the remaining bolts in the prescribed sequence.
Bring engine up to operating temperature (oil temperature approx. 80°C). Allow engine to cool and give cylinder head bolts a final tightening as described under 2.
DZGunner
PostPosted: Tue Mar 10, 2015 6:26 am    Post subject: Reply with quote
Thanks Ideola and Emoore.
1979 924 Sebring
1977 924
1977 924 (Parts)
