HELP need fuel pump for carbs
Ponz
PostPosted: Tue Jan 27, 2015 8:00 am    Post subject: HELP need fuel pump for carbs Reply with quote
What are you using for a fuel pump on your carbed engine. I lost the info and am lost. Car has been garaged for 7 years and we are trying to get the carbs fed.
I have a fuel pump in the engine compartment but I need a pump at the fuel tank. Tell me what you use.
Better yet describe your set up from the entrance of the fuel in the carbs to the gas tank. Having done the carbs in 1982 and three different mechs. on it I lost the thought. I have a fuel pump in the engine compartment but my carb guy says you need one pump at the rear near the gas tank.
Thanks for your help
Vince 1977 1/2 924, 2 weber 45DCOEs, mild cam, cam gear, euro pistons, an a headache.
77 1/2 track car
79 931 Euro
87 911 Targa
PostPosted: Tue Jan 27, 2015 8:07 am    Post subject: Reply with quote
I used this one from Cater. It worked great. Drove the car for over two years up to 200 miles at a time. Zero problems.
http://m.summitracing.com/parts/crt-p60504
Ponz
PostPosted: Tue Jan 27, 2015 8:22 am    Post subject: Reply with quote
Thanks for your help. I will look into it.
I did say I had weber carbs 2 of them 45DCOEs.
Thanks again
Vince
77 1/2 track car
79 931 Euro
87 911 Targa
PostPosted: Tue Jan 27, 2015 8:31 am    Post subject: Reply with quote
Yeah I had two DCOE 40s on my 77. As a bonus it mounts in the stock location and you can use the fuel return line to feed the carbs.
PostPosted: Tue Jan 27, 2015 10:24 am    Post subject: Reply with quote
In my Weber days everyone used Facet.
pcelenta
PostPosted: Tue Jan 27, 2015 10:32 am    Post subject: Reply with quote
second on the facet. for webers you need like 3 to 4 pounds. They have several different pumps. on my super 90 I am running dual dellortos (similiar to webers) and am upgrading to electric so I just bought part no. 41-2010-8 as it was recommended and "puts-out" in that range. It was like $70 bucks from an Amazon vendor called V dubstore. fast shipping.
pcelenta
PostPosted: Tue Jan 27, 2015 10:41 am    Post subject: Reply with quote
Mucho imporante. Be sure to put a good quality filter right before that there pump. They no like-a da dirt.
TJC
PostPosted: Wed Jan 28, 2015 5:24 am    Post subject: Reply with quote
Electric fuel pumps are "pushers" and your carb guy is correct in that it needs to be mounted near the tank as opposed to mechanical pumps which are "suckers' and are mounted on the engine. If the pump in your engine compartment is a high quality pump you can simply relocate it, however if it needs replacement I would go with, (providing you're not racing the car), a Holley Red as it will flow more than enough at 7psi for your needs and has a built in cleanable filter so you can place another fuel filter after the pump...the pumps like that better. I would also mount a quality fuel pressure regulator and fuel pressure gauge near the carbs since you may need make some adjustments so that you don't overwhelm the needles and seats in the carbs.
'95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com
ViktorTsoi
PostPosted: Thu Jan 29, 2015 3:02 am    Post subject: Reply with quote
I'm looking for one as well. Mine currently uses the stock fuel pump and surprisingly works (If you don't mind gas pouring into your engine bay). I brought a FPR with me when I picked it up and drove it 80 miles home but the fuel pump make bad noises when I turn the key on so I don't think this is an ideal set-up.
I used a carter pump similar to the one nick mentioned earlier for the weber in my truck (2.2L). Never had a problem with it (almost 3 years so far), so I'll probably try another one mounted by the tank.
1978 924 -parts car
1982 924 -sold
1985 944
Ponz
PostPosted: Thu Jan 29, 2015 4:56 am    Post subject: Reply with quote
The car is now running and sounds good. I only drove it a half mile and stopped as the muffler is shot and very loud
The fuel pump was relocated to the rear near the gas tank. I have a problem....which one do I drive now? My choice is ...........the 931 for its handling and the engine. The 911 is a great car and I will be making an announcement soon regarding this car.
Vince
77 1/2 track car
79 931 Euro
87 911 Targa
