ThomasJoseph315
PostPosted: Thu Oct 02, 2014 12:57 am    Post subject: ... Reply with quote
Last edited by ThomasJoseph315 on Sat Dec 12, 2015 5:59 am; edited 1 time in total
Ian89C4
PostPosted: Thu Oct 02, 2014 1:18 am    Post subject: Reply with quote
Which ones?
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
PostPosted: Thu Oct 02, 2014 3:08 am    Post subject: Reply with quote
Fronts aren't bad, just use a press or a decent vise and some sockets.
Rears another matter.
PostPosted: Fri Oct 03, 2014 5:20 am    Post subject: Reply with quote
Have a question, The ones that go on the back ends of the a arm. Do these need to be pressed on or hammered on with a big socket placed on the end of the bushing. Going for a alignment as soon as I'm done with the struts and have noticed that the beck end bushings on the control arm are not all the way on.
PostPosted: Fri Oct 03, 2014 6:55 am    Post subject: Reply with quote
I actually don't know as I replaced mine with polyurethane on the 924 and 968 pieces on the 951, both just slipped on with very little effort with a little grease.
I suspect that a press would be ideal, but a socket in a vise would work in a pinch and a socket and a hammer as a last resort (since you could damage the inner liner).
kcoyle
PostPosted: Fri Oct 03, 2014 10:59 pm    Post subject: Reply with quote
With my new A arms and new rubber bushings they slid on by hand with some dishsoap. I have about 100 miles on it so far so I guess its seated properly.
