924/early 944 fuse box interchangeability?
M030_986
PostPosted: Sun Sep 07, 2014 11:20 pm    Post subject: 924/early 944 fuse box interchangeability? Reply with quote
Among my little fleet of misfit Porsches, I've got a 78 924 that needs a fuse box due to water/corrosion damage. I have a good fuse box from an 84 944 and they sure look the same. Does anyone know for sure if they are actually the same part? Electrons and I don't get along too well,s so I want to try to do this only once. Thanks!
- Brian
gerben1986
PostPosted: Mon Sep 08, 2014 2:10 am    Post subject: Reply with quote
Did you check the PET of both the 924 and the 944? If the numbers are exactly the same the fusebox is also the same
911SC - 1980
M030_986
PostPosted: Mon Sep 08, 2014 6:27 am    Post subject: Reply with quote
They look identical but I won't know part numbers until I remove them both. At that point, I may as well try to plug the 944 box into the 924. I was hoping to find out if it will work, before tearing both cars apart
- Brian
PostPosted: Mon Sep 08, 2014 7:24 am    Post subject: Reply with quote
Fuse panel can be pulled apart and cleaned internally. Later cars added an extra fuse block, which may or may not be a problem for you.
