924 fuel pump relay
musicalannette
PostPosted: Wed Sep 03, 2014 10:46 am    Post subject: 924 fuel pump relay Reply with quote
saw this.
seems awfully expensive.
http://www.ebay.co.uk/itm/NEW-DME-FUEL-PUMP-RELAY-FOR-PORSCHE-924-/191274906986?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c88df756a
whats the going rate?
does anyone have a stash of old faulty relays? it might be possible to repair them, post shouldnt be too bad.
I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737.....
musicalannette
PostPosted: Wed Sep 03, 2014 11:00 am    Post subject: Re: 924 fuel pump relay Reply with quote
musicalannette wrote:
saw this.
does anyone have a stash of old faulty relays? it might be possible to repair them, postage shouldnt be too bad.
a lot depends which part has failed.
same with the ignition boxes, if there is a few to see if it is reparable then it might be worth me building a test rig 4 them.
CorsePerVita
PostPosted: Thu Sep 04, 2014 5:09 am    Post subject: Reply with quote
Pelicanparts has them for like $21 man.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2014.cgi?command=show_part_page&please_wait=N&SUPERCAT_FLAG=Y&make=POR&model=984&section=ELSWCH&page=3&bookmark=12&part_number=433-906-059-M252
Even if you ship it internationally it's STILL cheaper than the ebay part
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
musicalannette
PostPosted: Thu Sep 04, 2014 10:48 am    Post subject: Reply with quote
now that makes more sense.....I thought someone had opened a shop called daylight robbery.
thanks for pointing it out, if I need one on future ill go there.
!tom
PostPosted: Thu Sep 04, 2014 4:01 pm    Post subject: Reply with quote
It's not clear to me from these posts which relay you need.
The various years of 924's have a variety of fuel pump relays that work in different ways, with consequently varying prices.
78 924 NA
5-lug
9xx
PostPosted: Thu Sep 04, 2014 4:23 pm    Post subject: Reply with quote
KAE 3.300.300 relay quality is questionable. Few days ago I was driving to ice hockey rehearsal and noticed/heard that some relay started to buzz every time I tried to accelerate and eventually cut out the fuel delivery(?) if the acceleration continued.
Turned out it was the almost new KAE fuel pump relay. Luckily I had a spare one in the glove box.
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
musicalannette
PostPosted: Fri Sep 05, 2014 5:12 am    Post subject: Reply with quote
hi tom.
luckily im fine as far as needing one.
i remember a discussion before with you on this subject and you pointed me to a drawing of the relay circuit somewhere on this board, i tried and couldnt find it. but it seems the relay causes a lot of people bother. i think i remember someone saying they are hard to get hold of. what i was wondering is do they fail regulaly? if i could get hold of 5 or 10 faulty relays i might be able to see if it is a common fault, or if there was some weak link in the circuit, there might be a mod that could stop this from happening. if it is a common fault and not the relay machanism then it may be a $2 repair/mod after a bit of work. i would rather keep a few chips spare at a $1 than a relay.
nothing is worse than a car letting you down at the flick of a switch if it can be prevented. i like to be able to know im driving home every time i drive out. a breakdown wagon doesnt seem much fun.
i suppose a carrying a spare relay is a very good idea, but i think if you have a bit of skill, you might be able to make the components that fail pluggable so carrying a few chips that can plug in to the inside of the relay is a better idea at $2, or if we are lucky we might be able to add some protection to the circuit to stop it failing.
i will do another post, asking who has had a fail and how long it is for they had another failure.
really what i could do with is 10 or so faulty relays.
