Posted: Tue Jul 22, 2014 11:35 am Post subject: clutch feel.. |
what do your clutches feel like compared to other cars?
my 931 clutch has by a good margin the narrowest window of pedal travel where you can slip the clutch..
feels like maybe an inch of travel between where its disengaged and where its engaged..
its not really stiff compared to other cars but its much more like an on/off switch than a dimmer switch if you know what I mean..
I think it may be something aftermarket...
unless this is regular on 924's... and im wondering your opinion on it..
the gf hates it _________________ 80 Turbo - Slightly Modified |
CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Tue Jul 22, 2014 11:50 am Post subject: |
- N/A 924, effortless. Sorta mushy, not terrible. But OK.
- On the '79 N/A 924 I drove, the cable was a bit old and had a few split spots I had to consistently lube or it would get harder to engage. That was because it was dirty, nothing else. Aside from that, engaged like a mushy N/A 924 that was stock.
- Porsche 944 N/A. Mushy, not impressive. Replaced with aftermarket clutch, felt more direct, still effortless due to hydraulic.
- 931, more direct. Reminds me somewhat of the 944 N/A but mine certainly grabs harder. Uncertain if the clutch is stock or not.
- 951, the one I drove had an aftermarket clutch and grabbed hard. Easy engagement but grabby and very very direct. Not sure what a stock one feels like.
- 914, was adjusted almost too much on the side of almost no travel. Engaged quickly, and fairly quick since it was such a small and light car. Very little effort, but good feedback.
- 911, had it adjusted somewhere in the middle. Engaged well, good feedback, felt nice, grabbed decently and didn't chatter hardcore when slipping it lightly. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
jason c
Posted: Tue Jul 22, 2014 12:55 pm Post subject: |
Not normal.
Your car has been sitting for an extended period so you may have air in the system, bad fluid, leaking m/c or slave cylinder. You can try new fluid and bleeding. You should also check the wear on the clutch, engagement changes with wear. There is also a manual adjustment of the m/c rod to the pedal someone may have played with. |
CorsePerVita
Posted: Tue Jul 22, 2014 12:57 pm Post subject: |
| jason c wrote: | Not normal.
I was going to say, on the hydraulic cars, usually engaging at the very end of letting the pedal out is going to be air or worn clutch (or someone who didn't shim the pressure plate correctly with the throwout bearing) _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
Posted: Tue Jul 22, 2014 1:00 pm Post subject: |
thank you, that pretty much explains it..
my clutch did nothing the spring when it was cold, it just went to the floor and stayed there..
when it got warm out it started working like I thought it should, I couldn't really tell I just knew it acted ok and was doing its job..
so ok... ill rebuild that extra master cylinder and swap em out, then see how it feels... _________________ 80 Turbo - Slightly Modified |
CorsePerVita
Posted: Tue Jul 22, 2014 1:03 pm Post subject: |
| Fasteddie313 wrote: | | jason c wrote: | Not normal.
so ok... ill rebuild that extra master cylinder and swap em out, then see how it feels... |
That's definitely air in the system if it went to the floor. Symptoms of a leaky master or slave. Super easy to rebuild the slave. No rebuild kit that I'm aware of for the master, but together it is almost exactly $100 to rebuild and replace. (don't forget to replace that sh*tty blue hose that is probably cracked by now that feeds the master from the reservoir) _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
Posted: Tue Jul 22, 2014 1:05 pm Post subject: |
| CorsePerVita wrote: |
I was going to say, on the hydraulic cars, usually engaging at the very end of letting the pedal out is going to be air or worn clutch (or someone who didn't shim the pressure plate correctly with the throwout bearing) |
I bet, and hope that its air...
the clutch grabs fine and there is no vibration, doesn't slip under power, can break the rears loose too easily, the way it is it makes it harder not to spin on takeoff, you have to be very careful..
yes I know how to drive a stick, ha ha...... _________________ 80 Turbo - Slightly Modified |
jason c
Posted: Tue Jul 22, 2014 1:20 pm Post subject: |
Air can't get in the system without a leak. Water can & will be absorbed into the fluid though.
Its likely the m/c and/or the slave are shot. They can leak internally (can't build proper pressure) or externally. Change them both, cheaper than a tow that you will probably need if you don't.
The clutch will work even when down to the rivets. The pedal travel is related to the clutch disc thickness. There is a easy measurement procedure to check disc thickness. |
CorsePerVita
Posted: Tue Jul 22, 2014 1:33 pm Post subject: |
[quote="Fasteddie313"] | CorsePerVita wrote: |
yes I know how to drive a stick, ha ha...... |
Suuuuure suuuuuure  _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
