1984 944
billygoat
PostPosted: Thu Apr 17, 2014 8:41 am    Post subject: 1984 944 Reply with quote
does fuel pump run with key on or only when in start position
jason c
PostPosted: Thu Apr 17, 2014 11:41 am    Post subject: Reply with quote
It should not run constantly with the key on. What are you trying to do?
billygoat
PostPosted: Thu Apr 17, 2014 12:22 pm    Post subject: Reply with quote
get it started been sitting did tests no power to dme unit unless it only gets power when in start position
billygoat
PostPosted: Thu Apr 17, 2014 12:25 pm    Post subject: Reply with quote
its suppose to have 12 volt through pin 35 and 18 of dme plug no power with key on
jason c
PostPosted: Thu Apr 17, 2014 1:19 pm    Post subject: Reply with quote
Have you checked the relay and power & grounds to it?
scriblz7
PostPosted: Thu Apr 17, 2014 2:23 pm    Post subject: Reply with quote
try forums.rennlist.com they have a forum for the 944 which has a different fuel injection system from the 924
Riley
79 924 n/a with gt body
15 VW GTI
jason c
PostPosted: Thu Apr 17, 2014 2:38 pm    Post subject: Reply with quote
They're not very kind about grammar errors.
The 944 motronic system is not difficult.
9xx
PostPosted: Thu Apr 17, 2014 5:30 pm    Post subject: Reply with quote
http://www.the944.com/dmerelay.htm
Have you tried jumpering the DME relay socket?
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
