1982 924
billygoat
PostPosted: Sun Apr 13, 2014 1:34 am    Post subject: 1982 924 Reply with quote
will 1982 airvalve for fuel dissy work on 1979 924 its smaller
billygoat
PostPosted: Sun Apr 13, 2014 1:51 am    Post subject: Reply with quote
the round plate is smaller
ThomasJoseph315
PostPosted: Sun Apr 13, 2014 3:11 am    Post subject: Reply with quote
You talking about the Aux Air Valve?
billygoat
PostPosted: Sun Apr 13, 2014 7:17 am    Post subject: Reply with quote
im bad the sensor plate and housing
ThomasJoseph315
PostPosted: Sun Apr 13, 2014 7:30 am    Post subject: Reply with quote
I would assume not as the sensor plate is the metering device that controls the fuel flow in coloration with the amount of air pulling through the CIS system. Think of the throttle body valve, if that was smaller would the engine work properly?
What's going on with your parts? are they bent/broken or something?
Ian89C4
PostPosted: Sun Apr 13, 2014 9:08 am    Post subject: Reply with quote
no, they will not. I have tried and you will never be able to tune in the A/F mixture.
Cheers,
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
924-76
PostPosted: Sun Apr 13, 2014 9:17 am    Post subject: Reply with quote
What do you need? fuel distributor or the air sensor box?
I have an air sensor box if you need it
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
