what does the toofah say?
PostPosted: Sun Jan 19, 2014 5:37 pm    Post subject: what does the toofah say? Reply with quote
BAE! BAE!
Tiny little Mitsubishi TE04H from one of my old Chrysler 2.5L turbos, it's really too small for that motor, but is more sized for a 2.0L so it should work okay for the low boost levels I'll be shooting for.
Here's the intercooler I'll be using:
It's about the same size as the radiator and shood help cool the charge fairly well. I think it came from an Isuzu or Mitsubishi diesel box truck.
Should be fun!
PostPosted: Sun Jan 19, 2014 11:58 pm    Post subject: Reply with quote
That setup looks really heavy.
vatoisimo
PostPosted: Sat Jan 25, 2014 4:26 pm    Post subject: Reply with quote
is that going on the 24?
PostPosted: Sat Jan 25, 2014 5:35 pm    Post subject: Reply with quote
Yes. Yes it is.
Show up to the Portland Historical and I'll let you take it for a spin.
vatoisimo
PostPosted: Sun Jan 26, 2014 4:45 am    Post subject: Reply with quote
nice!
musicalannette
PostPosted: Sun Jan 26, 2014 5:47 am    Post subject: Reply with quote
So does the BAE stand for Big And Expensive?
sadly an old joke if you google BAE...
I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737.....
PostPosted: Sun Jan 26, 2014 2:51 pm    Post subject: Reply with quote
Bob's Automotive Engineering actually, but I get where you're coming from
As to the weight question brought up earlier, it isn't really that heavy as the intercooler is all aluminum and the end castings are fairly thin. The turbo manifold is lighter than or similar in weight to a stock manifold and the turbo TINY. Plus my 924 is very light in the front, so a little weight won't hurt it.
I need to get the car scaled before I dig into the turbo conversion to get a before/after with weights of the four corners, just for reference.
vatoisimo
PostPosted: Sun Jan 26, 2014 4:20 pm    Post subject: Reply with quote
you must be rolling in the dough if you are working on 2 Porches.
PostPosted: Sun Jan 26, 2014 5:07 pm    Post subject: Reply with quote
It's all about doing as much as you can yourself, taking your time, spreading things around and shopping around as muh as possible.
The manifold was found on CL.
Turbo was from my old turbo-dodge days and was rebuilt by me using an inexpensive rebuild kit.
The intercooler was $50 at the Portland Swap Meet.
The ceramic coatings weren't cheap, but worth it given the heat issues I've already had with this car and I put them in with the 951 parts I was already doing.
The exhaust downpipe will be home built and also coated.
Intercooler pipes will be built from scraps of rubber reinforced intake tubes gathered at the pick-n-pull and bits of exhaust pipe, unless I can find some aluminum tubing. This is a common solution for custom intercooler installs in the turbo dodge world and hold up to high boost levels.
Oil and water lines will be home made using Earl's hose. Radiator hose adapters will be used to provide water cooling for the center section.
The radiator needs to be rebuilt, so another core or two will be added to compensate, but a 944 or 951 rad could be used with some adaptation. Depends on pricing and availability.
The other option is to rebuild the bottom end to increase compression. That would be more expensive and not as fast.
The chassis and Top end has been prepped already, so why not make use of that work?
ThomasJoseph315
PostPosted: Thu Mar 27, 2014 1:00 am    Post subject: Reply with quote
Turbo,..
You and Grenadiers should come to Fontana for the "California Festival of Speed". Would be cool to see you guys and the mods you all made
PostPosted: Sat Mar 29, 2014 12:03 am    Post subject: Reply with quote
I would like to, but not going to pull the lump for another rebuild for a couple more weeks. If did get it done, there's a DE in Phoenix that weekend, much, much, much, closer~!
ThomasJoseph315
PostPosted: Sat Apr 05, 2014 2:27 am    Post subject: Reply with quote
We must show them what 924's can do!
http://eurotopian.com/thread/495/track-day-august-autoclub-speedway
