What's the best stuff to remove the sticky under the hood?
ThomasJoseph315
Guest
PostPosted: Tue Mar 25, 2014 8:03 am    Post subject: What's the best stuff to remove the sticky under the hood? Reply with quote
You know the glue that held the bubble wrap under the hood, the glue is all over, I'm thinking Goo Gone, but anything else? This stuff is really old.
billygoat
PostPosted: Tue Mar 25, 2014 8:53 am    Post subject: mineral spirts Reply with quote
goo gone has astone bad for paint
billygoat
PostPosted: Tue Mar 25, 2014 8:55 am    Post subject: remove glue Reply with quote
mineral spirts
Brian L.
PostPosted: Tue Mar 25, 2014 9:25 am    Post subject: That suff sucks! Reply with quote
Nothing works very good. I used gas with 2 stroke oil but I did a complete strip and repaint. I think Mr. billygoat is on the right track, solvent such as acetone lacquer thinner, gasoline just turns it into a gooey mess. I would try some WD40 to break the adhesion. Also here is a long shot, after all the foam is scraped off put a piece of sticky tape on it and see I that will pull it off.
1980 924 N.A. Monaco Blue owned since 1987
"Remember, sitting on your ass won't finish your project" -Puddins fab shop.
TYPE111
PostPosted: Tue Mar 25, 2014 9:30 am    Post subject: Reply with quote
I know on lotus cars where they use ultra sticky double sided tape people usually recommend bug and tar remover stuff from Auto Glym and the like.
Trust, Then Verify
snakoil
PostPosted: Tue Mar 25, 2014 6:48 pm    Post subject: Reply with quote
I like brake cleaner... Plus it smells good
1979 924 NA
jason c
PostPosted: Wed Mar 26, 2014 9:30 am    Post subject: Reply with quote
I did not tell him to say this. I was hoping Rasta would.
ThomasJoseph315
Guest
PostPosted: Wed Mar 26, 2014 11:58 am    Post subject: Reply with quote
Before
Almost after, going to work on it some more tomorrow.
I used a rag at first, but after a lot of useless scrubbing, I gave up and went and found this. I use these to clean gaskets off of blocks, worked pretty good. I just sprayed some Goo Gone for a cleaner where I was working on and a little a head to let it soak and it seems to be working pretty good. I might end up just repainting it eventually, well see.
