bellhousing ????????????? 1984 944
billygoat
PostPosted: Wed Mar 26, 2014 7:41 am    Post subject: bellhousing ????????????? 1984 944 Reply with quote
id number 944.116 .406 2r is this stock or a turbo bell hosing witch starter is right starter nut engaging fly wheel
PostPosted: Wed Mar 26, 2014 7:58 am    Post subject: Reply with quote
the 944 at the beginning of the part number indicates it is a 944 piece.
The 944 turbo would have a part number starting with 951 (unless the part was shared with the rest of 944 models)
However, that is a casting number and won't match up with the actual part number for that part.
billygoat
PostPosted: Wed Mar 26, 2014 8:12 am    Post subject: Reply with quote
isdo that why im having starter problems I saw other threads about I tdo I need a 951 starter or should I count teeth on fly wheel were is engine id located they may have changed engine
PostPosted: Wed Mar 26, 2014 8:40 am    Post subject: Reply with quote
Starters are the same between the 944 and 951. The difference is where the mounting holes for the starter are machined into the bellhousings.
Could be an issue with the ring gear, if someone has been in there and didn't assemble it correctly, you could be wasting your time chasing your tail.
Since you have the cam box off, I'd just pull the motor, replace the seals and hoses in the engine and verify the clutch, flywheel and ring gear are correct and correctly installed.
Doing the water pump and belts is easier to do with the engine on an engine stand anyway.
This might help you: http://www.porsche924-944.nl/manual/Haynes/01_Engine01.htm#_01_008
edredas
PostPosted: Wed Mar 26, 2014 8:51 am    Post subject: Reply with quote
Just to clarify, the 1985.5 944 and 924S share the same starter as the 951. My 924S also had the same bell housing as my 951 engine. The early 944 uses a different starter and bell housing.
EDIT: Fiat did you mean the same starter as 931?
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
billygoat
PostPosted: Wed Mar 26, 2014 9:46 am    Post subject: bell housing Reply with quote
went to clarks garage turbo clutch housing starts with 951 but starters for to 1985 944 are different they are also for 80 81 924
billygoat
PostPosted: Wed Mar 26, 2014 9:47 am    Post subject: bell housing Reply with quote
edredas
PostPosted: Wed Mar 26, 2014 10:32 am    Post subject: Reply with quote
There were some bellhousings with the 951 part number, and many that did not have them. The part number on both my 1987 924S and 1987 951 engine were 944 116 401 6R. The only difference that I could tell was that the 944 turbo had a stronger/deeper pressure plate.
So, you might have a late 944/951 bellhousing.
