TYPE111
Joined: 09 Feb 2014 Posts: 76 Location: Perth, Western Australia
Posted: Tue Mar 25, 2014 8:54 am Post subject: 924 v 944 Wing Mirrors |
Can a 944 electric mirror and motor with the twist type glass and motor be mounted to a 924 metal frame of the old three plug type?
My drivers side motor is kaput and is of the three plug type. I have the chance to get a 944 mirror with the twist type but the metal frame is a different colour and so I was hoping to keep the metal frame and just swap motors and mirror. Current mirror is cracked anyway.
Cheers
David _________________ Trust, Then Verify |
edredas
Posted: Tue Mar 25, 2014 9:43 am Post subject: |
If I am understanding you correctly, you are talking about the 1985.5 mirrors where you can remove the glass by twisting a mechanism at the bottom of the housing? If so, the glass in these mirrors are much larger than those of the 924 and early 944.
I hope that helps. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
TYPE111
Posted: Tue Mar 25, 2014 9:53 am Post subject: |
But if I am wanting to change the black plastic part, motor and mirror only, basically everything but the metal frame which bolts to the car, can I get away with putting all this onto the older metal frame? _________________ Trust, Then Verify |
edredas
Posted: Tue Mar 25, 2014 10:05 am Post subject: |
I don't think so, I believe the entire assembly; (housing and all) is larger on later cars. _________________ '84 944 -White, Brown interior
TYPE111
Posted: Tue Mar 25, 2014 10:09 am Post subject: |
That's a shame. Would have made life easier and cheaper. Thanks for your help.
edredas
Posted: Tue Mar 25, 2014 10:10 am Post subject: |
No problem... I've been down that road before. I had a early 944 sitting around and tried to use that mirror on my 924S, but it was much smaller and wouldn't work. _________________ '84 944 -White, Brown interior
