upper radiator hose
vatoisimo
PostPosted: Mon Dec 09, 2013 1:44 pm    Post subject: upper radiator hose Reply with quote
2.0 n/a question guys: Is there is any reason why you could not replace the steel upper radiator hose with a rubber one?
larchie
PostPosted: Mon Dec 09, 2013 2:50 pm    Post subject: Reply with quote
One reason might be upper hoses inexactly positioned are sometimes worn by other moving parts such as fan blades or the radiator pulley.
vatoisimo
PostPosted: Mon Dec 09, 2013 3:01 pm    Post subject: Reply with quote
do you think that the suction of the pump will cause the hose to collapse?
larchie
PostPosted: Mon Dec 09, 2013 3:17 pm    Post subject: Reply with quote
I don't know -- but you you're undoubtedly right since brand new hoses are quite pliable by hand.
PostPosted: Mon Dec 09, 2013 3:33 pm    Post subject: Reply with quote
Pump pushes water through that hose, not sucking through it. Lower hose has the suction and some hoses are built with a spring inside to prevent those issues.
I can't imagine there would be a huge issue, just make sure it is mounted securely and away from moving items that could cut it.
