2 broken magnets in 30 minutes
CorsePerVita
PostPosted: Sat Jul 27, 2013 8:58 am    Post subject: 2 broken magnets in 30 minutes Reply with quote
Well, i've had some odd intermittent firing and missing issues. As well as difficulty starting my race project lately. Upon inspecting it I found that the magnet inside had actually broken a chunk OFF inside. I have no idea how. I checked for off balance rotation and it seems smooth and perfectly fine. Very odd.
I gutted out a second distributor and took the magnet apart and put it inside the distributor. It ran great for about 30 seconds, then started to miss and stopped firing. It as well busted in the same spot, strangely enough.
I am absolutely baffled as to what may either be:
- Causing them to break
- Or if they were both just bad and worn and old to begin with
I'm unaware of any "electrical issues" that could cause the magnets to break. I doublechecked all my wiring. It's all great and checks out fine.
Pure coincidence? Old magnets? They did look sort of "spread" and "cracked" a little in the middle which makes me think they were just old parts and the rattling of the engine is enough to break it finally. Although 2 in one day? That seems odd... correlation isn't always causation. Ideas and suggestions for alternatives are of course open.
Is there an alternative to this setup? Something else I can do here?
Part of me wants to do a trigger wheel and a hall sensor pickup. The other part of me for simplicity sake wants to just replace the magnet. However, cheapest quote I've had is $60+ for a new one. I can do a trigger wheel + hall pickup for about the same amount.
So yeah I'm not really sure, sort of torn. Although if I replace the magnet, it makes me wonder: Will it just break again? Is there something obvious that could break them?
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Sun Jul 28, 2013 10:15 am    Post subject: Reply with quote
Maybe I'm too old school, but I have no idea what you mean by "magnet" in the distributor. Rotor, points, hall pickup, what?? Pics available?
Sorry for being obtuse,
Chuck
1981 924 Turbo sold
1982 924 Turbo sold
CorsePerVita
PostPosted: Sun Jul 28, 2013 11:20 pm    Post subject: Reply with quote
The magnetic pickup that screws to the coil itself.
- 1999 Ducati 900SS
ksis
PostPosted: Mon Jul 29, 2013 12:15 am    Post subject: Reply with quote
over tightening or flexing of the plates it the only way for it to crack. Have you tired to replace it and epoxy it back in place? May have to check mine also.....
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin
CorsePerVita
PostPosted: Mon Jul 29, 2013 12:46 am    Post subject: Reply with quote
Well, that's the odd thing. I didn't change anything, the first one just randomly broke. I suppose it's possible I overtightened the second one.
Can you actually epoxy the magnets back together? Wouldn't it affect polarity and mess it up?
- 1999 Ducati 900SS
PostPosted: Mon Jul 29, 2013 2:02 am    Post subject: Reply with quote
Ah, now I get it. Thanks for the pic. I've always used optical guts if I didn't have points in a dizzy.
1981 924 Turbo sold
1982 924 Turbo sold
CorsePerVita
PostPosted: Mon Jul 29, 2013 2:07 am    Post subject: Reply with quote
Optical guts?
- 1999 Ducati 900SS
PostPosted: Mon Jul 29, 2013 8:51 am    Post subject: Reply with quote
CorsePerVita wrote:
Optical guts?
LED contraption with round spinner that fits on the distributor shaft below the rotor and has 4 slots for light to pass through as the shaft spins. The LED thingy triggers the CD to fire. Sorry, no pics.
Like I said, old school---contraption, thingy. etc----you know, useful mechanical descriptions that don't offend prying eyes.
1981 924 Turbo sold
1982 924 Turbo sold
ksis
PostPosted: Tue Jul 30, 2013 12:42 am    Post subject: Reply with quote
look up Petronix or Crane Cams Fireball 3000. They are electronic ignitions systems. I will stand by the Crane Cams version. I ran them in my MG, Spitfire, TR6 and my bug. Yo can epoxy the magnet and it won't change the polarity.
64 Spitfire
76 TR6
04 Jetta
ksis
PostPosted: Tue Jul 30, 2013 12:43 am    Post subject: Reply with quote
64 Spitfire
76 TR6
04 Jetta
PostPosted: Tue Jul 30, 2013 5:55 am    Post subject: Reply with quote
Chuck
Never apologize for being obtuse! Obtusiousness (and closely related obtusity) is your right!
CorsePerVita
PostPosted: Tue Aug 06, 2013 12:50 am    Post subject: Reply with quote
I will look into petronix and an igniter and see if this is a feasible alternative. I need to understand why it broke the magnet first as I do not want to buy and break a petronix.
- 1999 Ducati 900SS
CorsePerVita
PostPosted: Wed Aug 07, 2013 11:48 am    Post subject: Reply with quote
There is nothing I hate more than when people find a solution or their problem and never follow up in a thread since others may encounter the same issue. So just to ensure I don't end up being "That guy" I figured I'd share the issue.
The screws that I installed the distributor with were too long. I'm uncertain how I mixed them up. The distributor screws that mount the innards are generally shorter and only go into the actual distributor parts.
Upon inspecting the magnet for the "interference" I noticed a pattern on both distributor magnets breaking in the same spot. I also noticed a glossy imprint where the screw goes in, and an obvious indicator that the screw had pushed the magnet apart and literally broke it in half.
So be absolutely certain when you reinstall or rebuild your distributor that you use the proper screws with proper lengths. Ensure that you are not installing screws too long that could push or break the magnet. That is exactly what happened and why I went through 2 magnets. I'm a tad upset that I ruined 2 perfectly good magnets in the pickup portion of the setup, but now I know and learned.
Just sharing "for future reference"...
- 1999 Ducati 900SS
