Fuel filter
Dean47
PostPosted: Sat Jul 13, 2013 9:12 am    Post subject: Fuel filter Reply with quote
I have a 1977.5 na 924. It has a fuel filter between tank and fuel pump. Is this stock or was it added? Parts house says there shouldn't be one there, is this true? Should I replace or remove it, Im changing my filters and found this one.
PostPosted: Sat Jul 13, 2013 10:10 am    Post subject: Reply with quote
My '77 had a small right angle filter before the pump. It is a filter/ strainer to keep large chunks out of the pump. I couldn't find a new one so just reversed flushed it with solvent.
Being that is 1/2" or 12mm pipe we couldn't find anything in the parts book at FLAPS the even came close. I didn't try Porsche.
Mike
'67 MG Midget Dp
agfisher
PostPosted: Sat Jul 13, 2013 10:39 am    Post subject: Reply with quote
Is this what you are talking about?
http://www.924board.org/viewtopic.php?t=26247&highlight=
1977 924 N/A Martini Edition
scm924s
PostPosted: Sat Jul 13, 2013 6:05 pm    Post subject: Reply with quote
Tried to get one from Porsche in UK for my Martini, and was told they are no longer available. Gave mine a good blast with the air line.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
xanderdeg
PostPosted: Mon Jul 15, 2013 2:29 pm    Post subject: Reply with quote
I washed mine out thoroughly with water and let it dry overnight. Works just fine
ThomasJoseph315
PostPosted: Mon Jul 15, 2013 3:11 pm    Post subject: Reply with quote
Pretty sure pelican parts has this,.. give them a call
