water pump with plastic impeller
pcelenta
PostPosted: Sun May 05, 2013 8:55 am    Post subject: water pump with plastic impeller Reply with quote
so I picked up a water pump for the 80 S1 from autozone...opened the box and it looked like the usual GMB pump casting wise...then I flipped it over to find a plastic impeller. quite odd but I suppose new technology. I am a little sketchy on the idea of a plastic impeller. what are the thoughts out there? return it and get a GMB with metal impeller or give this one a try.
PostPosted: Sun May 05, 2013 10:10 am    Post subject: Reply with quote
Beemer pumps have been constructed this way for years.
PostPosted: Sun May 05, 2013 11:18 am    Post subject: Reply with quote
I've had a few plastic impellers slip on the shaft and the engine runs hot. Fix was to pin the impeller.
1981 924 Turbo sold
1982 924 Turbo sold
mikebola
PostPosted: Mon May 06, 2013 9:09 am    Post subject: Reply with quote
working for a company that uses plastic turbines and impellers on steel axles that are made to spin up to 30k rpm, I have to agree that it's only a matter of time before it slips on the axle, even if it's knurled or flattened.
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
emoore924
PostPosted: Mon May 06, 2013 11:21 am    Post subject: Reply with quote
Having replaced a couple of those BMW plastic impeller pumps with the much more desirable metal impeller pumps, I can tell you the BMW crowd does not like the plastic pumps, myself included.
I've never seen a plastic impeller 924 (early) pump.
pcelenta
PostPosted: Tue May 07, 2013 4:37 am    Post subject: Reply with quote
autozone must have a new supplier because the last one I picked up from them had a metal impeller. I have to look to see if it is pinned...if not I may just bring it back.
txjake
PostPosted: Tue May 07, 2013 5:59 am    Post subject: Reply with quote
never met a plastic impeller that I liked
1978 924, aka The Red Rocker
PostPosted: Tue May 07, 2013 7:36 am    Post subject: Reply with quote
The ones I provide are GEBA brand and are all metal.
Water pump by itself is $63 + shipping.
pcelenta
PostPosted: Thu May 09, 2013 1:43 am    Post subject: Reply with quote
thanks dan, I'll be ordering from you shortly.
regards,
