924 Rear diffuser
Horizonblue
PostPosted: Sun Apr 28, 2013 7:31 am    Post subject: 924 Rear diffuser Reply with quote
Some time ago, I purchased this one on ebay, and now it's time to mount it on the car.
I thought it was a bolt on and go (paint in between), so I was dissapointed to see that it didn't fit. I mean, it is very bad, it's like my car is one inch longer than the car this came from.
I have seen them on a few of the last 924s. This one I have here, is not original, it's made from fibreglass.
But it fits so bad that there must be some other thing wrong, than just a bad copy.
Is the bodywork a bit different in the back of the early 924, compared to the last 924?
Euro 924, 1976
"If you can't fix it, don't break it"
/P.G. Andersen
BionicBalls
PostPosted: Sun Apr 28, 2013 10:30 am    Post subject: Reply with quote
That is a diffuser from a 944 Turbo. It has a different bumper setup.
1980 924 NA
1982 931
Horizonblue
PostPosted: Sun Apr 28, 2013 5:57 pm    Post subject: Reply with quote
Sure about that?
I bought it, since it looks like this one, found on the last 924s.
You will notice that this one follows the wheel arch a bit upwards, while the 944 turbo doesn't.
Euro 924, 1976
/P.G. Andersen
PostPosted: Sun Apr 28, 2013 6:57 pm    Post subject: Reply with quote
definately not from a 944 turbo,
you've got one like this below... the key difference is where the edge starts behind the rear arch. as you can see below the valance butts up against the wheel well, the 944 turbo version starts behind the arch contour in about 2 inches. The styles are also different as the 44 version is level whereas you version curves up towards the rear hatch.
http://www.google.com.au/imgres?imgurl=http://www.porsche-foorum.org/album/albums/userpics/10026/valge2.jpg&imgrefurl=http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/677971-1979-porsche-924-5speed-1000-allentown.html&h=600&w=800&sz=183&tbnid=Qg1PJw4bG6kZmM:&tbnh=97&tbnw=129&prev=/search%3Fq%3D924%2Brear%2Bvalance%26tbm%3Disch%26tbo%3Du&zoom=1&q=924+rear+valance&usg=__2VM1wJhEjPEIj0ei29YD4sLLzEw=&docid=6JWRxcJ3Y1DZdM&sa=X&ei=zON8Ub-qF-m1iQeY5YGYDQ&ved=0CHUQ9QEwCg&dur=2157
Horizonblue
PostPosted: Mon Apr 29, 2013 6:05 am    Post subject: Reply with quote
Seen here, everything looks ok.
But here is the problem.
If the car was 1 inch shorter, the protrusion (with the circle around) would slip up between the bumper and the bodywork, which I believe it is meant to. The arrow is pointing at a hole in the diffuser, which can't be used for anything, since there is a gap there, created by the protrusion.
The other part of the diffuser (for the right side) is completely impossible to mount.
Any suggestions?
Euro 924, 1976
/P.G. Andersen
PostPosted: Tue Apr 30, 2013 7:14 pm    Post subject: Reply with quote
Your mounting angle looks wrong, you can see thst it tilts up towards the edge of ths rubber on the bumper. So far as mounting it next to the muffler you might need to fab up some mounts. Pretty surf an 80/81 has a point where this would be able to be mounted, not sure about earlier designs jad a different heat shield in the rear.
Raceboy
PostPosted: Tue Apr 30, 2013 7:25 pm    Post subject: Reply with quote
I have the same diffuser (though original part, made by BBS) on my white 924:
The part that you have is correct shape, but the heat shield may be not original perhaps? You have to drill a hole for the bolt and it would bolt right up.
The diffuser, side skirts and front valance were optional on late 924 S'es, it was supposed to be standard equipment on 924's what were meant to be 924 S2 (narrow body with late oval dash, late windscreen etc).
My Gulf racer was one of the prototypes of that kind, unfortunately the PO did not know this and just saw it as a good platform for a racer and bought it for that from Germany.
Few years ago there was also one of those for sale in mobile24 for 22 000 euros, had all the paperwork which proved that the car belonged to Porsche until early 90'es. ~20 or so were made.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Horizonblue
PostPosted: Wed May 01, 2013 5:40 am    Post subject: Reply with quote
Raceboy, that diffuser on your car looks great.
It's a strange problem.
On the pictures, you will see that mine is held in place by a small jack. I have placed the diffuser, so it follows the wheel arch and the side of the car quite ok. If I move it, so the protrusion slips in between the bumper and the bodywork, it fits like crap anywhere else.
I guess there is nothing else to do, than cut it into pieces and glue/fiberglass/fill/sand it together again, with the loose parts attached to the car. I have actually already started, by cutting the right part into two pieces. As it was, it could never fit the car. I might as well just have bolted a toilet seat under the bumper....
Euro 924, 1976
/P.G. Andersen
Raceboy
PostPosted: Wed May 01, 2013 7:58 am    Post subject: Reply with quote
Whoa, just wait a second on this! I can take photos of mine tomorrow, how it fits, my guess is that you are cutting a wrong thing and it really should be the heat shield, not the valance.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Horizonblue
PostPosted: Wed May 01, 2013 3:12 pm    Post subject: Reply with quote
A few pictures would be great, I will wait a bit, before I cut it into more pieces
Euro 924, 1976
/P.G. Andersen
edredas
PostPosted: Sun May 05, 2013 7:02 am    Post subject: Reply with quote
Here's what it looks like underneath a 924S. It is similar, if not identical to the 951, and the holes for the diffuser are already there.
There were perhaps a hundred or so 924's that had an oval dash built over the years. These were factory test cars equipped with latest 944 engines/components. The idea was to make them look bland so that no one would ever suspect anything. They were usually built in batches of 10-20, and were used as company cars or leased to employees after testing. Some are well documented and their past is no secret.
When the 944 switched to the oval dash, the price increased substantially. Porsche didn't just improve the interior, they built an entirely new chassis to go with it. Building a production 924 on this platform wasn't remotely considered. At the time, Porsche was just looking to build a cheap/powerful car that could better compete with Japanese sports cars. So, they took an early 944, slapped some 924 fenders on it and called it the 924S. At first, they wanted it to look different than the old 924, but due to cost constraints they had to strip it down to the carpet. While this was a noble idea, it didn't really work. The Japanese cars had a long list of standard options and cost considerably less. The 924S never really stood a chance.
To put it in perspective, if you didn't check the box for a radio on the options sheet, you not only didn't get a radio, but you also didn't get the wiring! They were so depesperate to cut costs that they literally started removing wiring. The oval dash wouldn't have only increased the price of 924S, but it would've been competing with their own 944. With the 924S, they were just looking to cash in on what appeared to be a growing market. Later on they dropped the 924S and base 944. They decided instead to focus on building cars with more standard options and leave the cheap cars to the Japanese.
Sorry, about the long post, and if you need any more pictures just let me know.
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
Horizonblue
PostPosted: Mon May 06, 2013 2:00 am    Post subject: Reply with quote
Thanks for the picture, here is how my car looks like, from approx. the same angle.
The difference, whatever it might be, is not really obvious. But like I said, it's like my car is one inch too long. The right side of the diffuser, was impossible to mount. It's like the spare wheel well sits too far back.....
Oh, on the picture you can actually see the right part of the diffuser which I have now cut into two pieces
I'm afraid that's the only way to go, cut it into pieces, mount it on the car, and fiberglass it together again.
Euro 924, 1976
/P.G. Andersen
Raceboy
PostPosted: Mon May 06, 2013 3:45 pm    Post subject: Reply with quote
I took the photo of the rear of my 1983 924 NA, will upload it after work.
I wouldn't cut it apart, but rather would modify the sheet metal.
edredas, where is the information coming from regarding number of prototypes built? I have been into 924's for ~15 years and kept an eye on them in mobile.de on regular basis and also in forums but until this moment only seen two such prototypes: one is mine and other is the one I mentioned eariler.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
edredas
PostPosted: Tue May 07, 2013 6:54 pm    Post subject: Reply with quote
Horizonblue, I measured roughly 108mm between these two points. I know it's of no use now, but I'm curious to see if your car is longer?
Raceboy, the number I gave was just an estimate. It isn't clear how many were built, but there were quite a few batches made. I don't want to clutter up his thread with off-topic pictures, so sometime later today I might start a thread in 924S discussions.
Horizonblue
PostPosted: Wed May 08, 2013 6:03 am    Post subject: Reply with quote
Edredas:
I have approx. the same dimension between the two points, maybe a few mm more.
That is if you are pointing at the point I think you are. If I measure the total length of the sheet metal here, I have 150 mm.
Euro 924, 1976
/P.G. Andersen
