agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
Posted: Tue Oct 02, 2012 10:51 am Post subject: Replacing Rear Fuel Lines |
I really need to clean up all the lines in the back of my 924 from the fuel tank to the hard lines. I think it's like 6 lines and the fittings. Here's my idea and please shoot holes in it.
1) Cut the compression sleeves off of all the hoses fittings.
2) Remove and toss the old fuel lines.
3) Drop the fittings into my tumbler(http://www.eastwood.com/ew-hd-vibratory-tumbler-w-media-pushbutton.html) for cleaning and polishing.
4) Electro-plate the fittings (http://www.eastwood.com/ew-electroplating-system-tin-zinc.html)
5) Re-assemble the hoses using fuel injection line and fuel injection clamps?
So how does that sound? I'm assuming that fuel injection hoses and clamps can deal with the pressures coming from the fuel pump? _________________ 1977 924 N/A Martini Edition |
Posted: Tue Oct 02, 2012 12:16 pm Post subject: |
You could also see if there is an Oil Filter Service or Hydraulic hose shop near you. They can rebuild the lines with new hose, clamps, etc.
I use braided line with EFI clamps. I'm also running about 50psi. Though I can say that I've dead-headed the system a few times with no leaks.
Pay attention to the vent lines as well, they can cause gas fumes in the cabin or worse (since it is the fumes that ignite) _________________ Stefan
agfisher
Posted: Thu Oct 11, 2012 11:39 am Post subject: |
| fiat22turbo wrote: | | You could also see if there is an Oil Filter Service or Hydraulic hose shop near you. They can rebuild the lines with new hose, clamps, etc. |
I look into that.
| fiat22turbo wrote: | | I use braided line with EFI clamps. I'm also running about 50psi. Though I can say that I've dead-headed the system a few times with no leaks. |
Dead-headed?
| fiat22turbo wrote: | | Pay attention to the vent lines as well, they can cause gas fumes in the cabin or worse (since it is the fumes that ignite) |
Will do. Thanks? _________________ 1977 924 N/A Martini Edition |
Posted: Thu Oct 11, 2012 3:48 pm Post subject: |
Dead-headed. Meaning to run the pump's full capabilities into the system with no pressure relief. _________________ Stefan
agfisher
Posted: Fri Oct 12, 2012 4:35 am Post subject: |
Well that makes sense. So it sounds like this solution could work pretty well and clean up those rear fuel line which are a real mess. _________________ 1977 924 N/A Martini Edition |
agfisher
Posted: Wed Oct 24, 2012 6:05 am Post subject: |
I believe I used -6 as that was what I had and it fit the standard fittings with an EFI hose clamp to hold the hose in place.
The trick is to cut the old hose off and re-use the stock fittings, saves money and unless the fittings are damaged they fit perfectly on the odd-ball metric bubble flare fittings that Porsche used. _________________ Stefan
agfisher
Posted: Wed Oct 24, 2012 6:36 am Post subject: |
OK, I will measure the current line to make sure but I think this will be the way to go. Clean up all that mess in back and should be a good solution for people who don't want to pay for NOS or parts warehouse place prices. _________________ 1977 924 N/A Martini Edition |
jim kleyh
Joined: 24 Apr 2012 Posts: 55 Location: pine falls, manitoba, canada
Posted: Tue Oct 30, 2012 5:15 pm Post subject: pics |
Hi from the frozen north. Any chance for some pics showing the final layout? etc. JIM _________________ oldcarman-77 porsche 924 and one of the ugliest motorhomes on earth. |
agfisher
Posted: Tue Oct 30, 2012 9:42 pm Post subject: |
Sure thing. I'll try to document the whole process. Not sure when I'll get started but hopefully soon! _________________ 1977 924 N/A Martini Edition |
agfisher
Posted: Wed Aug 10, 2016 6:08 am Post subject: |
Sorry to resurrect such an old post but I finally have time to start working on this so I thought I would point you to where I'm documenting the process.
http://www.924board.org/viewtopic.php?p=383382#383382 _________________ 1977 924 N/A Martini Edition |
brian19600
agfisher
Posted: Wed Aug 10, 2016 11:47 am Post subject: |
Where'd you get the accumulators? _________________ 1977 924 N/A Martini Edition |
brian19600
Posted: Wed Aug 10, 2016 8:08 pm Post subject: |
I got them off ebay. I've been watching it for a while and waiting for some to come up. Apparently they are used on mid-70's 911's too. The cheapest I see them right now is $108.00. _________________ 78 924 |
brian19600
