chriss931
Posted: Sat Sep 08, 2012 2:38 am Post subject: broken fill plug on transmission!?! ahhh! |
| Problem is exactly what the title says. Its on a 80 931 with the snailshell. One side of the plug (the length of one side of the 17mm Allen) is broken off. Every time i try and loosen it the Allen slips out. Any advise? I'm thinking about tapping on the broken edge with a screwdriver and hammer but don't know if this will cause more broken parts. |
Posted: Sat Sep 08, 2012 2:58 am Post subject: |
Pull the transmission and take it to a machine shop to pull the plug out for you. _________________ Stefan
Posted: Sat Sep 08, 2012 3:34 am Post subject: |
Get a 17mm trans filler plug removal tool. Use a hacksaw to cut off the end of the tool. Use a 17mm wrench and see if you can break it loose. I find that using the wrench helps keep the bit flush and prevents it from twisting out of the filler plug. It may also help to spray some PB Blaster and let that sit overnight, then before you start wrenching, heat it up thoroughly with a propane torch. If all of that doesn't work, then the next best thing is to tack weld the cut-off portion of the allen bit to the plug and then twist it out with the wrench. Alternatively, you can use a bolt with a 17mm head and tack weld that in place, and then tack weld a nut onto the threads of the bolt and use that to turn out the filler plug. _________________ erstwhile owner of just about every 924 variant ever made |
chriss931
Posted: Sat Sep 08, 2012 4:24 am Post subject: |
| Yeah that sounds like that's what I'll have to do. Do you know what material the plug is by chance m |
Posted: Sat Sep 08, 2012 4:50 am Post subject: |
+1 to what ideola said.
its just some steel...you dont really have to worry about it much...it will weld to most not expensive keys/screws you want to sacrifice. _________________ Supercharger and EFI kits
https://www.the924.com |
chriss931
Posted: Sat Sep 08, 2012 8:42 am Post subject: |
| Thanks guys ive been struggling with this for a couple days now and couldn't figure it out for the life of me. |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Sat Sep 08, 2012 11:41 pm Post subject: |
Been there. It was ugly.
 _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
chriss931
Posted: Sun Sep 09, 2012 1:35 am Post subject: |
| Ohhhh you aren't kidding. Did you have to heat it up when you took it out or did you just wrench it out |
Posted: Sun Sep 09, 2012 2:21 am Post subject: |
kcoyle
Posted: Sun Sep 09, 2012 6:58 am Post subject: |
I tried all the basics first. Heat (mapp gas torch), PB blaster, BFH. I actually think it was the heat of the welder that finally helped get it out. Otherwise I believe I would have been screwed. Apparently the PO couldn't get it out either because the fluid in there was gross and kinda low.
I would heat it up ALOT and see how that goes. _________________ 1982 931- Stock with MBC at 8psi
