Krgracing
Joined: 02 Jun 2012 Posts: 3 Location: Bunbury, western Australia
Posted: Sat Jun 02, 2012 11:55 am Post subject: Timing over advancing when starting |
I'm new here but had my 924 about 6 months, it is giving me grief when trying to start. I've had the starter motor rebuilt by an auto electrician, also checked the alternator and replaced the battery.
Recently I've added all the earth strap upgrades and taken it to another auto electrician for a second opinion.
It appears the timing is over advancing on start up and the starter motor comes to a halt mid crank. After trying two or three times it will eventually crank normally and start.
I just replaced the dist cap and rotor and backed the timing off but this has made little improvement. Just ordered a Hayes manual too but in the meantime has anyone had a similar problem ? Any ideas?
Thanks. _________________ 80' 924 auto
86' 944 man
94' 968 man
Current car is an 82' 924 man |
Ozzie
Posted: Sat Jun 02, 2012 3:52 pm Post subject: |
I'd double check the valve timing _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
Posted: Sat Jun 02, 2012 11:32 pm Post subject: |
Also, make sure you don't have an injector leaking which is causing a hydrolock on one cylinder.
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
Ozzie
Posted: Sun Jun 03, 2012 9:42 am Post subject: |
Hydrolock is definitely a possibility.
check for coolant loss and check oil for fuel contamination. _________________ Porsche 924 1984 (UK import) NA
sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Sun Jun 03, 2012 10:12 am Post subject: |
| Ozzie wrote: | | I'd double check the valve timing |
how would one go about doing this? _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns |
Posted: Sun Jun 03, 2012 2:59 pm Post subject: |
Put it on TDC per flywheel mark, then check the mark on the cam sprocket against the pointer on the valve cover. If no mark on the cam gear, rotate the crank 360 degrees and look again (you can also look at the distributor to eliminate this step, but I HATE removing my dizzy cap).
If still unconvinced, you can pop the valve cover. . .if #1 is at TDC, #4 should be at overlap. _________________ Toofah King Bad
sciroccosteve
Posted: Sun Jun 03, 2012 11:11 pm Post subject: |
| Rasta Monsta wrote: | Put it on TDC per flywheel mark, then check the mark on the cam sprocket against the pointer on the valve cover. If no mark on the cam gear, rotate the crank 360 degrees and look again (you can also look at the distributor to eliminate this step, but I HATE removing my dizzy cap).
If still unconvinced, you can pop the valve cover. . .if #1 is at TDC, #4 should be at overlap. |
gotchya, thanks man. _________________ 1979 924
2000 V6 Passat
Raceboy
Posted: Mon Jun 04, 2012 1:44 am Post subject: |
It is one of the most frequent problems of 924: worn out starter motor bushings that cause the starter motor to halt during cranking. It is usually ok when engine is cold, but when the engine is hot, the starter stalls. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
sciroccosteve
Posted: Mon Jun 04, 2012 3:37 am Post subject: |
| Raceboy wrote: | | It is one of the most frequent problems of 924: worn out starter motor bushings that cause the starter motor to halt during cranking. It is usually ok when engine is cold, but when the engine is hot, the starter stalls. |
I can vouch for this! _________________ 1979 924
2000 V6 Passat
musicalannette
Posted: Tue Jun 05, 2012 11:53 am Post subject: |
It sounds from the advice that it is probably not timing thats at fault, but to be sure I would double check with a timing light when you try to start it.
It will let you know when your spark is actually firing, it will advance when you rev the engine, but to remember you have set the engine timing with the vacume advance hose disconnected (assumng you can get is started).
Whatever happens the timing should not "move" around when the engine is at a constant speed. If you can get the engine spinning freely on the starter or ticking over it should be pretty constant. If you can get it to spin or tickover then its worth a check, it will advance as rpm increases, it will advance more if the vacume advance is connected and it will advance quickly when you rev it if the vacume is connected.
All the engine timing is carried out in the dizzy IIRC, here are bob weight which give a general timing profile. perhaps a bit more retard on the dizzy to see if goes away might be a cheap shot in the dark. i would retard until it wont start, you can always turn it back. cost you nothing to try it .
hope this helps _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
Krgracing
Posted: Wed Jun 06, 2012 5:11 pm Post subject: |
Thanks heaps to everyone who responded!
Hydra lock is something I hadnt considered and I will double check the timing too. If the car has points I've read they may need adjusting and can cause poor starting.
I think the starter motor is to blame and I'm glad to hear its a common thing with 924's, from searching the net the starter motor never gets a mention just bad earths, and points to electronic ignition.
When did 924's go from points ignition to electronic ? I've pulled and replaced the cap and rotor but couldn't get any further. Workshop manual arrives today hopefully.
Thanks again _________________ 80' 924 auto
86' 944 man
94' 968 man
Krgracing
Posted: Wed Jun 27, 2012 11:35 am Post subject: solved ! |
Just to conclude this thread.
The reason for the poor cranking and starter motor issues was the initial ignition timing was too far advanced. Every time I retarded the timing the engine would struggle to idle but what the mechanic did was play with the air / fuel mixture screw near the throttle body. This bought the idle up and leaned the mix off.
At the ideal position between too rich and too lean the mechanic advised I go half way betweeen counting the number of turns made. The central position resulted in an idle speed of 1600 rpm so unfortunatly I had to further richen the mix until the idle was around 1000 rpm.
Runs good now and starts ! _________________ 80' 924 auto
86' 944 man
94' 968 man
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Wed Jun 27, 2012 12:22 pm Post subject: |
On the throttle body? That's the idle screw. The mixture screw is down a hole in the top of the air-mass meter assembly.
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
Posted: Wed Jun 27, 2012 12:36 pm Post subject: |
Yep, or you`ve got a vacuum leak, or some DH has screwed with the butterefly stop screw thinking it is idle adjustment.
Would also check the dizzy centrifugal advance and the total advance myself, not pay a mechanic (even a Porsche one ) who appears to be guessing. _________________ World`s quickest 924 2L slushbox
| Allan @ DTA wrote: | | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
Ozzie
Posted: Wed Jun 27, 2012 8:40 pm Post subject: |
if the springs in the centrifugal advance are shot or missing it can cause lots of problems too. _________________ Porsche 924 1984 (UK import) NA
