Lefrog
Joined: 18 Dec 2006 Posts: 8 Location: Montréal , Québec ,Canada
Posted: Mon Jan 08, 2007 7:25 am Post subject: What part i need to make a 5 bolt conversion???. |
What part i need to make a 5 bolt conversion ???? do i have to change the front spindle??? Please dont refere me at the FAQ section,
I just find a 1986 944 and i want to know what can i have to buy front and rear.....
Thanks _________________ Porsche 924 1982
VW New Beetle 2000
VW Golf Cabriolet 1992
VW Caravelle GL 1992 (Eurovan) |
Neil924
Posted: Mon Jan 08, 2007 8:41 am Post subject: |
Use the search button at the top, all answers are there.
Good day to you sir. |
Posted: Mon Jan 08, 2007 8:51 am Post subject: |
NEW:
- Rotors
- Pads
- Wheel bearings and wheel seals
- SS brake hoses
- Hand brake cables
- Lug nuts
- Brake hardware kits
REBUILT:
- Calipers (only $45 each at EBS Racing)
SALVAGE (5 bolt 924, Pre-85.5 944 NA):
- Steering knuckles, with spindle nuts and thrust washers
- Dust shields (front & rear)
- Hard lines, rear (from trailing arms)
- Caliper carriers, rear
- Hubs, front & rear
- Handbrake hardware (shoes, actuators, adjusters, springs)
- Wheels & spare tire
You may also need a 931 or M471 master cylinder, depending on your year and model. . .check PET. Don't use 944 calipers!!!
Good luck,
rasta
PS That Neil is a salty one, ain't he? _________________ Toofah King Bad
Last edited by Rasta Monsta on Tue Apr 10, 2007 12:49 am; edited 3 times in total |
Lizard
Posted: Mon Jan 08, 2007 9:58 am Post subject: |
this is all in the FAQs,
why should we NOT refer you to them? Were they written for a reason? do a search and RTFAQ first.
parts from a 1986 will not work for a 5 bolt conversion. _________________ 3 928s, |
Neil924
Posted: Mon Jan 08, 2007 10:46 am Post subject: |
| Rasta Monsta wrote: | NEW:
- Rotors
- Pads
- SS brake hoses
- Hand brake cables
- Lug nuts
REBUILT:
SALVAGE (5 bolt 924, early 944 NA):
Good luck,
rasta
PS That Neil is a salty one, ain't he? |
How could I have said it more better?
Search and read what's called "Asked Questions and then ask by posting.
And by the way posting a new thread is the longer way of getting the info. |
Posted: Mon Jan 08, 2007 11:29 am Post subject: |
Well, I replied because I was in OPs position not long ago, and found the information in the FAQ and Tech Section a bit difficult to sift through due to organizational. . .um, "issues" - there is not a simple parts list anywhere to be found.
My two cents.
rasta
P.S. Good day to you, as well! _________________ Toofah King Bad
Lefrog
Posted: Mon Jan 08, 2007 11:57 am Post subject: |
| Neil924 wrote: | Use the search button at the top, all answers are there.
If i Search (5 bolt conversion) i got 2874 matches!!!!But nothing, give me clear indication as Rasta Monsta
Rasta Monsta just give me what i need to do my conversion!!!! _________________ Porsche 924 1982
VW New Beetle 2000
Lefrog
Posted: Mon Jan 08, 2007 11:58 am Post subject: |
- Rotors
- Pads
- SS brake hoses
- Hand brake cables
- Lug nuts
REBUILT:
Good luck,
rasta
Many many thanks Rasta Monsta  _________________ Porsche 924 1982
VW New Beetle 2000
Lefrog
Posted: Mon Jan 08, 2007 12:00 pm Post subject: |
| Lizard wrote: | this is all in the FAQs,
(((((parts from a 1986 will not work for a 5 bolt conversion.))))) | Thanks  _________________ Porsche 924 1982
VW New Beetle 2000
Posted: Mon Jan 08, 2007 2:14 pm Post subject: |
| Lefrog wrote: | | If i Search (5 bolt conversion) i got 2874 matches!!!!! |
Always click "Search for all terms" when searching with more than 1 word and you want topics that include all of them. In the case of "5 bolt conversion", with "Search for all terms" selected, you get a mere 147 topics to sift through.
Here's an enjoyable one - http://www.924board.org/viewtopic.php?t=15544 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Ozzie
Posted: Mon Jan 08, 2007 3:36 pm Post subject: |
You also may need to replace the trailing arms.
If you have the lighter ones use them, save a bit of weight. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Mon Jan 08, 2007 3:38 pm Post subject: |
| Ozzie wrote: | | You also may need to replace the trailing arms. |
Optional, it all bolts to the existing suspension, including axle stubs. _________________ Toofah King Bad
gohim
Posted: Mon Jan 08, 2007 6:16 pm Post subject: |
If you have a 79 or earlier 924, you should upgrade to the 23mm+ master cylinder of the 80 and later 924 and 931. If you have an early 924, and use the 80 master cylinder, then you don't have to change your stoplight wiring. If you have a early 924, and use a 81 or later 924 or 931 master cylinder, you must switch to the stoplight switch on the brake pedal used on the later 924, 924S and 944.
You can use the front and rear brake calipers from any 944 (82-8 . The rear calipers are the same for all 924, 924S, and 944 models up to 88. Some people claim that you can't use 944 front calipers, because the 944 calipers used a different size piston bore on them, and used a master cylinder with a stepped cylinder diameter. The fact is that 924 and 931 models 80-85, and 944 (82-83) used the same 477 prefix front calipers, even though the 924 and 931 used the same straight diameter 23mm master cylinder for both disc/drum cars and four wheel disc cars. After 84 944 and 924S used front calipers with a 944 prefix, but they used the same master cylinder as the earliest 944. The earliest 944 (82-83) used the same stepped master cylinder as later 944, but they still used the same front calipers as the 924 and 931. The last 944 and 924S used a different master cylinder that the 924, 931, earlier (82-86) 944.
924S (86 and later) and 944 (85/2 and later) with alloy rear trailing arms use different length (longer) rear wheel axles and eliminate the spacers that were used on early 944 and 924 and 931 cars with four wheel disc brakes. So you can't easily use the rear wheel axles from a 85/2 944 or 924S with changing to the alloy rear trailing arms.
I recommend installing seal kits in any used caliper before installing. Rotors only have 1.5mm to 2.0mm of wear thickness when new. It makes more sense to buy new rotors, then to buy used rotors, and paying for shipping when they probably are already worn-out. |
maxiblu
Posted: Mon Nov 05, 2007 1:16 am Post subject: 5 bolt conversion |
Don't mean to dump on you Gohim, but I have a 1980 931 with front calipers I can't rebuild cause the piston is a different diameter than later 931's and 944's. I may have a strange car cause it dosen't have a rear sway bar and some other items that apparently were standard items on 931's. Anyway, after these calipers fail I'm gonna find a 944 parts car and switch everything from the clutch back to the 931. At the very least it will make parts easier to find. _________________ 1980 931
1984 944
1975 MGB
1973 MG Midget H Prod |
Posted: Mon Nov 05, 2007 2:11 am Post subject: |
hehehehee
btw heh...search function never returned anything clear to me neighter...but hey..its there and it helped a bit  _________________ Supercharger and EFI kits
https://www.the924.com |
