The perfect oil.
PostPosted: Tue Apr 12, 2011 1:39 pm    Post subject: The perfect oil. Reply with quote
So many people ask the question. So many different answers. This is my vote for all around use.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
PostPosted: Tue Apr 12, 2011 3:52 pm    Post subject: Reply with quote
El Chato
PostPosted: Tue Apr 12, 2011 5:04 pm    Post subject: Reply with quote
I had to order mine, no one in El Paso carries it. Still have it on the side for the engine rebuild.
1979 924 N/A, Snail Shell
1980 924 N/A
1976 924 N/A
It may be that your whole purpose in life is simply to serve as a warning to others.
Today's weirdness is tomorrow's reason why.
PostPosted: Wed Apr 13, 2011 8:50 am    Post subject: Reply with quote
That should coke your bearings.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
agfisher
PostPosted: Thu Apr 14, 2011 4:29 am    Post subject: Reply with quote
Just make sure it's cold-pressed!
1977 924 N/A Martini Edition
PostPosted: Thu Apr 14, 2011 6:19 am    Post subject: Reply with quote
this is the one i use....its simply perfect.
http://www.turnermotorsport.com/image/fluids/motul_300V_competition_sae_15w50_synthetic_engine_oil_2_liter_1.jpg
v8carreragts
PostPosted: Thu Apr 14, 2011 6:57 am    Post subject: Reply with quote
I use AmsOil as well. I've been using it since 1980.
2015 AUDI Q7
2013 Chevy Cruze
Jakkq
PostPosted: Sat May 07, 2011 12:34 pm    Post subject: Reply with quote
What is the best formula to use? E.g. 0W-40
1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/
PostPosted: Sun May 08, 2011 3:20 am    Post subject: Reply with quote
I would not suggest using 0w40 oil in our cars. Can't really speak for the audi 2.0 engine as that is not my area. Running 10 30 to 20 50 depending on the conditions seems appropriate for the 2.5. The 10 40 pictured covers a broad range of operating temperatures. This is not an oil you drain every 3 months, you can run this stuff for a year if you wish depending on operating conditions. That is why i picked a weight that will work in a broad range of temperatures. Some of my cars only get 1000 miles a year put on them and it just makes no sense to dump a lot of oil. If I was racing I would go with a heavier weight, if I was living in alaska I would go lighter.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
PostPosted: Sun May 08, 2011 5:02 am    Post subject: Reply with quote
Lower cold viscosity number is always better for the engine since you will have a lubricant which flows much better at cold starts, even on summer days. But it often costs more money and if you dont have so much of it spend it else were and buy a cheaper 5w or 10w40 instead.
