Anyone ever use a tow dolly?
dgz924s
PostPosted: Mon Jan 19, 2009 10:51 pm    Post subject: Anyone ever use a tow dolly? Reply with quote
Hello all....Want to know if you have used a dolly to tow and/or if it is ok to use?......Towing your 924 specifically.
tia!
Dal
Dal Glassinger
924guy
PostPosted: Mon Jan 19, 2009 11:11 pm    Post subject: Reply with quote
thousands of miles..never a problem...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
dgz924s
PostPosted: Mon Jan 19, 2009 11:20 pm    Post subject: Reply with quote
Ok Eric thanks! Will it make any difference that the car is lowered as low as possible? I have an airdam but I could remove it.
Dal Glassinger
PostPosted: Mon Jan 19, 2009 11:22 pm    Post subject: Reply with quote
Suggest removing it.
Vince Ponz
PostPosted: Tue Jan 20, 2009 1:27 am    Post subject: Reply with quote
Remove it.
If not get a long block of wood and put it under the front wheels just before the spoiler comes to the trailer.
Careful now.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
dgz924s
PostPosted: Tue Jan 20, 2009 2:01 am    Post subject: Reply with quote
Thanks for the replies!!....uhaul claims the dolly is designed to accomodate lowered cars and airdam/spoilers. But I asked here because you are not trying to rent me one.......like they are!
Dal Glassinger
Andrew NZ
PostPosted: Tue Jan 20, 2009 2:07 pm    Post subject: Reply with quote
I used to use one with mine until I lowered it, and then it hit the center pivot bolt of the dolly on the sump over bumps . I guess it depends on the design of the dolly.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
PostPosted: Tue Jan 20, 2009 2:18 pm    Post subject: Reply with quote
My car is lowered and I have used a tow dolly many times without issue.
I've also been able to get my roommates' 951 on a tow dolly.
moorepower
PostPosted: Tue Jan 27, 2009 10:06 am    Post subject: Reply with quote
Do y'all remove the halfshafts from the transaxle, or do anything special when you tow on a dolly? I'm pulling home an '82 931 parts car this weekend, and I don't want to mess up the transaxle or anything, especially since the trans is the main reason I bought the car.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
Rich H
PostPosted: Tue Jan 27, 2009 10:13 am    Post subject: Reply with quote
If in doubt drop them.
PostPosted: Tue Jan 27, 2009 11:22 am    Post subject: Reply with quote
If the tranny is what you want, you'll need to remove the half shafts anyhow.
That said, I have used a tow dolly many times without disconnecting anything. Just double check that you have the car in neutral and don't try backing up.
moorepower
PostPosted: Tue Jan 27, 2009 12:00 pm    Post subject: Reply with quote
Thanks guys. I was trying to avoid rolling around in the mud in the seller's yard while taking them loose, but I think I'll bite the bullet and yank them out. I'd be seriously pissed at myself if I messed up the trans.
Dan.
PostPosted: Tue Jan 27, 2009 12:02 pm    Post subject: Reply with quote
OK, we've been over this before, if the car is in neutral and your pulling it, how can that be any harder on the gearbox than DRIVING the car????
Leave 'em attached and deal with it when you get home. You're not going to hurt anything.
mehall
PostPosted: Tue Jan 27, 2009 12:03 pm    Post subject: Reply with quote
Pull it a short way to a parking lot, throw down a couple sheets of cardboard, and then remove the shafts. You stay out of the mud, and your tranny is OK.
Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org
PostPosted: Tue Jan 27, 2009 12:19 pm    Post subject: Reply with quote
How far are you pulling it?
