hadrian017
Posted: Mon Feb 21, 2011 10:01 pm Post subject: Is this a good option ? |
Found this on ebay:http://cgi.ebay.com/ebaymotors/WHEEL-RIM-4-5-BOLT-LUG-ADAPTERS-MUSTANG-64-66-67-69-/370485027491?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3APorsche%7CModel%3A924&hash=item5642a0e2a3
I would like to convert my 924 from 4 tug to 5 tug _________________ www.myspace.com/hadrianmansueto
www.myspace.com/tapedivision check ouy my music  |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Mon Feb 21, 2011 11:50 pm Post subject: |
really interesting but that thing is quite hefty at 2inches wide
you'll have to be careful of the offset on the wheels you buy to go with it.
Definitely easier and cheaper than a disc brake 5 lug conversion from a 944 _________________ 1979 924 NA |
hadrian017
Posted: Tue Feb 22, 2011 9:02 am Post subject: |
| snakoil wrote: | really interesting but that thing is quite hefty at 2inches wide
Definitely easier and cheaper than a disc brake 5 lug conversion from a 944 |
My wheels are not aligned with the body because i have fitted a carerra gt kit so the wheels needs to be pulled a bit to become aligned with the body so i thin i can afford this kind of space right ? _________________ www.myspace.com/hadrianmansueto
mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Tue Feb 22, 2011 9:27 pm Post subject: |
| hadrian017 wrote: |
My wheels are not aligned with the body because i have fitted a carerra gt kit so the wheels needs to be pulled a bit to become aligned with the body so i thin i can afford this kind of space right ? |
I don't know if they'd work. you'd have to measure the offset of your wheels and then factor it into the depth of the spacer you're looking at. _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
