A wild wire coming off the fuse block
Rattlinbone
PostPosted: Sun Jan 30, 2011 9:49 am    Post subject: A wild wire coming off the fuse block Reply with quote
Okay, get a load of this:
Looking over the fuse block, I found a wire that had been crimped to a fuse post (9, I think) That does not appear to be factory spec to me. I traced the wire back all the way to the fuel pump. I think this is powering the fuel pump! What the #### is up with that?
Fred- 1979 924
PostPosted: Sun Jan 30, 2011 12:38 pm    Post subject: Reply with quote
Make another trip to Taco Bell after you reattach it.
staticsan
PostPosted: Sun Jan 30, 2011 1:04 pm    Post subject: Reply with quote
It looks like a PO had a failed fuel pump relay and couldn't find or couldn't be bothered to find the correct one. The fuel pump relay has a timeout circuit driven by tacho pulses that must work or you won't get any fuel pumping.
Wade.
