924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon Jan 09, 2012 11:20 pm Post subject: Fuel pump OEM $650.50 inc or replacement |
Fuel pump OEM or replacement
Recieved a quote today for a new fuel pump from porsche for my 1980 ROW 924 Manual non turbo
91160810200 fuel pump is $650.50 inc
the best I can find for bosch part 91160810200 that I think is the correct part is $250
Any other tried and tested brands out there ?
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Tue Jan 10, 2012 11:12 am Post subject: |
Pierburg fuel pump should work. You're talking about the inline pump right? I've got one for sale if you end up needing one. _________________ 1980 924 NA
1982 931 |
924aussie
Posted: Tue Jan 10, 2012 11:22 am Post subject: |
Yes the inline not intank, if it is new PM me the price please
ksis
Posted: Tue Jan 10, 2012 1:02 pm Post subject: |
Look for a pump that fits the 2.0 fuel injected VW wesfalia campers or the 83 v6 Jaguar. Both pump the same cfm and psi as what we need. I havge found both work but you need to cut the wire harness to accept male plugs or eyelets. I can get the VW pump for 160.00. _________________ 77 924
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin |
john h
Mr Bitey
Joined: 23 Sep 2011 Posts: 54 Location: Perth, Western Australia
Posted: Thu Jan 12, 2012 11:51 am Post subject: |
I purchased one from the USA on eBay.
Really cheap and haven't had any problems. _________________ Tom
___________
1979 924 NA
1979 924 NA - Parts car |
Vic
Posted: Thu Jan 12, 2012 3:23 pm Post subject: fuel pump |
| I bought one off ebay and even with the normal high postage it was still under $200 |
924aussie
Posted: Thu Jan 12, 2012 7:41 pm Post subject: |
The Aussie guys, what brand did you get off ebay ?
Vic
Posted: Thu Jan 12, 2012 8:43 pm Post subject: fuel pump |
| I honestly cant remember but I'll climb under her tomorrow as she's up on blocks at the moment,to check it out, mine is the turbo model so i remember the internal one was $187 or there abouts, but the external one was supplied by the bloke i bought the car off and it was in the boot in a box but i reckon i've thrown the box out, PELICAN parts in the US has been great for me and they have pumps in the $200 bracket plus about $30 postage, will get back to you tomorrow with the part name, I assume the non turbo pump is the same |
Vic
Posted: Fri Jan 13, 2012 2:26 pm Post subject: fuel pump |
| Alan, log on to ebay and type in : gmb fuel pump porsche 924 and the first unit that is shown on sale from "cbhausmaster" is the same as mine and it works fine, less than $200 including postage |
924aussie
Posted: Sat Jan 14, 2012 11:23 am Post subject: |
Thank you
924aussie
Posted: Sat Jan 21, 2012 12:04 am Post subject: |
Ok I have the new external fuel pump, is there any way of bench testing it before I crawl under the car and put it in ,like resistence figures etc, just incase it is a dud ?
Also when you put a new fuel filter in I understand that you pour fuel through it before you put it in so that the initial surge of pressured fuel doesnt "blow' internal filter pieces off they will then lodge further down the system. Do you pre fill, soak, pour through any fuel in the external fuel pump ?
Vic
Posted: Sat Jan 21, 2012 7:06 am Post subject: fuel pump |
| Alan, In my situation, I had to replace both pumps as mine is a turbo with an internal pump as well, i just installed them and also left the old fuel filter hooked up in case of any crap, i also fitted a new relay as the car had been idle for 6/7 years, flushed the tank out when i removed internal pump, then she fired up after a few cranks, I didn't do anything else like pouring fuel through, etc,or test ,you should hear it pumping when you put ignition on,thats how i tested , I'm going to fit a new fuel filter shortly as well as i might even remove internal pump again as it has a filter on its intake side which might have picked some debris so i'm gonna clean it as a precaution, that's all, cheers |
