ignition switch removal
old97
PostPosted: Sun Jan 22, 2012 9:20 am    Post subject: ignition switch removal Reply with quote
I need to replace my ignition switch (just the switch part) on a 1980 924.
I would like to know if anyone can give me a heads up on the procedure before I drag out the BFH.
Ozzie
PostPosted: Sun Jan 22, 2012 1:24 pm    Post subject: Reply with quote
Remove s/wheel.
remove surround and column switches
undo allen key bolt on bottom of ign lock assy and remove assy.
replace ign switch
assembly is reverse of removal.
I think there is a write up with pics in the How-To section.
Its AUTO and its BLACK
Montego Black on black/red
old97
PostPosted: Mon Jan 23, 2012 8:26 am    Post subject: Reply with quote
Thanks, I did find the procedure after my post
