OH NOOOOOOOO....................
jamis1970
PostPosted: Tue Nov 16, 2010 10:28 am    Post subject: OH NOOOOOOOO.................... Reply with quote
went to give my car some love- (change the gear oil) only to discover the gear oil FILL plug (passenger side correct?) is completely useless. PO must have set a bomb off on it as there is nothing left for the 17 mm hex to fit onto. I will not show you a picture of this mess as I do not wish anyone to get sick. I cant believe a 17mm hex head bolt can get so wasted. the hex head is no longer there just the remnants of some twisted schrapnel. What can I do? drill it out? the damage is so bad I dont think i can do anything to get it out. anyone have any thoughts/ideas? 79 snail
1979 924 N/A Not Fast, but a BLAST to drive.
buldogo2
PostPosted: Tue Nov 16, 2010 11:01 am    Post subject: Re: OH NOOOOOOOO.................... Reply with quote
Take a dremol, and grind down 2 sides of the bold until you can fit a 16mm spanner. Then hope the bold is not corroded stuck
jamis1970
PostPosted: Tue Nov 16, 2010 11:23 am    Post subject: Reply with quote
thanks ill give it a try- I was wondering if i could weld something to it to help get it out. Ill soak it in penatrating oil in the meantime. keep suggestions coming.
924 sport
PostPosted: Tue Nov 16, 2010 11:45 am    Post subject: Reply with quote
Find a nut thats slightly bigger then the mangled plug head,Clean everything ,then weld inside of nut to mangled plug. 2 short welds will do it,Quelch quickly with a wet rag.Keep a fire extinguisher handy incase .Once completed, gently undo nut taping with a hammer
lightly as you go.Generally works a treat.
jamis1970
PostPosted: Tue Nov 16, 2010 1:50 pm    Post subject: Reply with quote
ok I talked with a mechanic friend and he said welding a bolt head was a good idea- He wanted me to ask is the drain plug steel, aluminum or something else.
Piglet
PostPosted: Tue Nov 16, 2010 2:03 pm    Post subject: Reply with quote
That's how i did it two weeks ago.... worked fine after days of messing with oil, hammer, grip pliers etc.
If you've got a welder, that's the way to go, 10 minute job....
white 1984, 924 "non options"
JayZzzz4
PostPosted: Tue Nov 16, 2010 2:11 pm    Post subject: Reply with quote
It might be fine just for two spot welds.... but I would be a little worried about welded anything to the transmission. Heating up extremely hot in a short time frame in one spot = uneven heating = warping , and transmissions have tight tolerances. Just a heads up, I'm sure it's fine to do. And what 924 sport said is a good idea, trans oils might cause a small fire.
White 1987 Porsche 924S manual
BionicBalls
PostPosted: Tue Nov 16, 2010 3:01 pm    Post subject: Reply with quote
why not just get a good pair of vise grips and crank down on it?
1980 924 NA
1982 931
jamis1970
PostPosted: Tue Nov 16, 2010 3:06 pm    Post subject: Reply with quote
there is nothing left for visegrips to grab on to but thanks!
Thats the ball bustin I mean knuckle bustin way,
that wont do.
Ozzie
PostPosted: Tue Nov 16, 2010 9:20 pm    Post subject: Reply with quote
welding a nut or bolt into it is usually the way.
drilling may get swarf in the gear box- bad ju ju.
Its AUTO and its BLACK
Montego Black on black/red
Harm
PostPosted: Tue Nov 16, 2010 9:41 pm    Post subject: Re: OH NOOOOOOOO.................... Reply with quote
Ozzie wrote:
…drilling may get swarf in the gear box- bad ju ju.
True… BTDT and cleaned it all up afterwards.
The weld road you wanna go Jamis…
Regards, Harm.
Rich H
PostPosted: Tue Nov 16, 2010 10:00 pm    Post subject: Reply with quote
Casing is big and ali, the plug is small and steel, welding a couple of short tacks will barely warm the gearbox casing, it's too fast. the plug will get hot (Obviously) but it'd take a massive amount of heat to distort the case, even then being ali it's probably melt first.
It might be possible to grind a notch in the plug and tap it round with a drift and hammer?
PostPosted: Tue Nov 16, 2010 11:40 pm    Post subject: Reply with quote
X2 on Rich H, had to do that to a Ford Escort oil pan plug. It is a huge case for the amount of welding involved. Heat in the case is not an issue.
Mike
'67 MG Midget Dp
BionicBalls
PostPosted: Wed Nov 17, 2010 3:14 am    Post subject: Reply with quote
If you're worried about heat, you could try using some JB weld or some other epoxy.
1980 924 NA
1982 931
