1980 924 Fuel Accumulator - Earlier version OK?
Robb Northrup
PostPosted: Sun May 11, 2014 9:22 am    Post subject: 1980 924 Fuel Accumulator - Earlier version OK? Reply with quote
Have to replace the accumulator. Noticed that 1976-78 accumulators a lot cheaper than 1980/Turbo versions. Would an earlier version work for my 1980?
I've owned too many cars. 1980 Porsche 924 with European bumpers
larchie
PostPosted: Sun May 11, 2014 10:24 am    Post subject: Reply with quote
The older pressure accumulator has only 20 cm^3 volume and has a cracking sound when the engine is shut off. Two accumulators were used. The newer pressure accumulator beginning in 1979 has 40cm^3 and according to Porsche not only reduces the cracking noise in the fuel system when engine in stopped, but also helps with warm starts.
