bvonarx
Joined: 26 Aug 2009 Posts: 7 Location: The Garden State
Posted: Thu Jun 03, 2010 3:48 am Post subject: Removing Pine Sap from Hood |
What is the recommended method and materials for removing pine sap from the the exterior without scratching or marring the paint? I've read lots of different suggestions (Skin So Soft, WD-40 etc )but am not convinced they are absolutely safe to use, any ideas? _________________ Best regards,
Brooks
Sous les pavés, la plage |
Andre'
Joined: 21 Feb 2009 Posts: 85 Location: North Carolina (Blue Ridge Mountains)
Posted: Fri Jun 04, 2010 8:45 pm Post subject: |
| Try Paint Thinner or Mineral Spirits - won't harm your paint. See if you can find that stuff women use to clean their fingernails (nail polish?) - this works, too. |
924guy
Posted: Fri Jun 04, 2010 10:36 pm Post subject: |
light duty citrus cleaner and a plastic razor blade. park the car in the sun for a bit first, put some of the citrus cleaner on a rag and then gently work the sap with the plastic scraper. itll usually pop off in chunks... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
931Owner
Joined: 14 Feb 2009 Posts: 352 Location: Chicago NW Suburbs
Posted: Mon Jun 07, 2010 2:49 pm Post subject: |
| Andre' wrote: | | See if you can find that stuff women use to clean their fingernails (nail polish?) - this works, too. |
Andre... I think you were thinking of Nail polish REMOVER or acetone and use use it sparingly until the area is smooth to the touch.
I usually use nail polish to touch up deep dings which go to the metal when I don't have touch up paint.
A clay bar from a good automotive paint shop is probably your best bet. _________________ 1980 Turbo
-too many cars and too many motobikes |
Gracie
Joined: 29 Nov 2004 Posts: 35 Location: Alberta, Canada. T9W1S9
Posted: Sat Jul 31, 2010 3:46 am Post subject: |
RM's 9OO or wax and grease remover AFTER you have Hot soap and water cleaned. Chamois will not scratch with soap and water and then for 900 a non scratching paper towel. Allow the 900 to sit for awhile. (few minutes.) _________________ Working on cars is restful for they have neither conflict nor emotion.
Time with cars is never wasted, even if all you do is stand there and curse at the unfinished impossibly curved 1/4 panel. |
pjs
Posted: Thu Sep 16, 2010 12:37 am Post subject: |
| I use rubbing alcohol and a cotton ball or paper towel, then hit with a bit of polish, works every time. |
Posted: Thu Sep 16, 2010 3:31 am Post subject: |
We have stuff called Goof off the ultimate remover.
Takes off latex paint, marker,glue, gum, adhesives, grease n oil, sticker residue, lipstick and scuff marks. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
