trey3670
Posted: Tue Sep 14, 2010 11:34 am Post subject: AC Question |
found part of the answer (how to turn on cool air,but not really) with search.
OK heres the thing. I turn the big knob all the way to the left and the ring also,but if I am running the other fan,dedicated heater fan? it will shut off and a loud fan noise comes from the area behind the glove box,but no air flow,what gives?
does it have two fans? heater ac?87 924s thanks ahead of time,  |
Sleykin
Joined: 30 Apr 2003 Posts: 758 Location: Medford, Oregon USA
Posted: Tue Sep 14, 2010 12:59 pm Post subject: |
Yes it has two fans. One for heat and fresh air and one for A/C.
You shouldn't be able to turn on both fans at the same time.
Not really sure what you need to know? _________________ Glenn Neff
Medford, OR
87' 924S |
trey3670
Posted: Tue Sep 14, 2010 1:02 pm Post subject: |
| when I turn on the ac fan I get no airflow,is there a broken control or something? I can hear the fan running,does it put out air through the same ducts as the heater? |
Sleykin
Posted: Tue Sep 14, 2010 1:24 pm Post subject: |
It does put out the same vents as the heater. The sliding levers move the airflow up and down and there are flaps that can close the dash vents but it could be a vacuum motor problem or the cable has disconected from one of the levers. Take a look at this link.
http://clarks-garage.com/phpBB2/viewtopic.php?t=3038
I have my dash out right now and took a bunch of pictures but I need to figure out how to get em here. _________________ Glenn Neff
Medford, OR
87' 924S |
