can an exhaust leak cause this...?
B
PostPosted: Sat May 29, 2010 11:02 am    Post subject: can an exhaust leak cause this...? Reply with quote
Hi everyone-
this seems like a strange question - but I started my car up yesterday and it was slow to get going. I know it needs a second or two to warm up and has seemed fine after that however - it was not coming up on the rpm's so I opened the hood to check a few things and within a few seconds it started to come to life and the rpm's came up to around 900.
I did not think much about it and closed the hood. By the time I got back into the car it started to choke and stumble again.
I opened the hood again - and yes the rpm's rose and levelled off. through all of this I did notice that my connection to the turbo was giving off fumes and some smoke.
As strange as this sounds can this exhaust leak have anything to do with the motor choking?
any thoughts or opinions would be greatly appreciated.
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
jbwheele
PostPosted: Tue Mar 01, 2011 7:15 pm    Post subject: Check Spark eads shorting out on bonnet and battery etc. Reply with quote
Check for elec short, dizzy is near hood and also battery
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
Imafordguy
PostPosted: Wed Mar 02, 2011 4:37 am    Post subject: Reply with quote
The exaust leek is definently in need of attention... It is not the source of your issue.
I would have to agree with the previous post. Check out what the hood is coming in contact with, throttle linkage, dist, battery(but that is not likely), etc.
81 Porsche 924
84 Porsche 944(parting it)
66 Ford f100
66 AC cobra kit car(major project)
64 ford f100 (429 SCJ)
62 Studebaker golden hawk gt
61 baja bug (with bad opel 1.8, looking at ford 2.3 turbo to flovo)
PostPosted: Wed Mar 02, 2011 4:50 am    Post subject: Reply with quote
Holy old post, batman!
B
PostPosted: Wed Mar 02, 2011 7:08 am    Post subject: Reply with quote
sorry I had forgot about this
the top of the coil was coming into contact with the hood - once it was moved down, it seems ok - the exhaust I will re-check when the weather breaks
thanks
1979 924 n/a
BAE turbo
5-speed snailshell
9XX Girl!
PostPosted: Wed Mar 02, 2011 8:55 am    Post subject: Reply with quote
B wrote:
....the exhaust I will re-check when the weather breaks thanks
B? please don't drive with a leaky exhaust?
When you are driving (with the windows up in your bad weather) and you start to feel lethargic, do you put down to "you work hard" or..... is it really the carbon monoxide?
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
B
PostPosted: Wed Mar 02, 2011 9:01 am    Post subject: Reply with quote
thanks
I guess I should include that my 924 has not reached year round status yet - I know blasphemy -
I was getting ready to do my spring projects before the thaw and after the road salt has been at least somewhat removed.
Brakes and exhaust are at the top of the list -
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
