A noisy tappet is a happy tappet
PostPosted: Tue Mar 23, 2010 5:09 am    Post subject: A noisy tappet is a happy tappet Reply with quote
But how much noise is too much noise?
*will upload video soon*
PostPosted: Tue Mar 23, 2010 7:54 am    Post subject: Reply with quote
When one or two sound happier than the others.
PostPosted: Tue Mar 23, 2010 8:25 am    Post subject: Reply with quote
Hmm.. mech steth the beth meth for that?
Min
PostPosted: Wed Mar 24, 2010 11:27 pm    Post subject: Reply with quote
If you think they are getting noisier.... open the cover and check them, I didn't and I mushroomed one/seized my motor.
Min
ic932
PostPosted: Mon Mar 29, 2010 8:28 am    Post subject: Reply with quote
I've got a same situation but worse lol. Never had a 931 with a bad lifter so... been reading about 928 lifters (944). Never took any interest into how they actually function... I presume they have the same/similar concept? Nobody wants to remove the cam...or cams. Any update?
PostPosted: Mon Mar 29, 2010 8:43 am    Post subject: Reply with quote
944/928 lifters are not nearly the same as 924 lifters.
ic932
PostPosted: Mon Mar 29, 2010 8:50 am    Post subject: Reply with quote
OK, what mechanism (if any) do 924 lifters use? Is entirely hydraulic?
PostPosted: Mon Mar 29, 2010 10:14 am    Post subject: Reply with quote
924 lifters are purely mechanical, the tip of the valve stem makes direct mechanical contact with the lifter adjust screw, which is used to adjust the clearance.
ic932
PostPosted: Mon Mar 29, 2010 2:39 pm    Post subject: Reply with quote
Of course they are
Who can forget those grub screws?
I've got hyraulic lifter woes on my brain, excuse my stupidity.
PostPosted: Mon Mar 29, 2010 3:11 pm    Post subject: Reply with quote
Why not pop off your valve cover and take a look? Roll up the sleeves, get your hands dirty, and report back? Better than sponging others' R&D!
ic932
PostPosted: Tue Mar 30, 2010 6:24 am    Post subject: Reply with quote
Hehehe...Ok Rasta I derserved that.
Besides, my my tappet issue(s) are for hyraulic lifters and thier relationship to oil supply/pressure. OT so no need to report back here.
