Advanced (?) CIS Query
PostPosted: Wed Apr 21, 2010 1:20 am    Post subject: Advanced (?) CIS Query Reply with quote
Shaggy is getting a digital control pressure regulator. I am wondering if I should eliminate the "lambda loop" (narrow band O2, TPS, digitally controlled frequency valve, lambda computer).
It seems like its main purposes (fine idle adjustment & WOT enrichment) won't be needed with the UTCIS. Since I am having new lines built, I am in a position to cleanly delete the frequency valve. I especially don't want a "battle of pressures" between the UT controller and lambda controller at idle.
Thoughts?
PostPosted: Wed Apr 21, 2010 4:29 am    Post subject: Reply with quote
The tps is needed for the ignition. Is it incorporated on in the fuel system on the us cars? If I were in your seat i would remove the lamda system and run open loop. It must be a pain to tune in the utcis while the lambda always tries to "correct" the AFR. I assume you dont have a cat anymore.
PostPosted: Wed Apr 21, 2010 10:47 am    Post subject: Reply with quote
I don't believe TPS does anything for SI ignition. Got one interesting response at Pelican in the 930 section:
JFairman wrote:
There won't be any battle of pressures since control pressure and the lambda fuel head lower chamber pressure are completely unrelated.
If you have emission testing than leave the lambda stuff in there, if not it's up to you.
PostPosted: Wed Apr 21, 2010 11:15 am    Post subject: Reply with quote
Agreed. AFAIK, the ignition setup on the S1 is nearly identical in function to the 1981-onward NAs. On those cars, I believe the TPS serves only as WOT enrichment.
stevekat
PostPosted: Wed Apr 21, 2010 5:15 pm    Post subject: Reply with quote
My Lambda system and UTCIS seem to work well together.
Also, I have posted in the board before, my narrowband AF gauge goes rich at 3300 rpm or so, regardless of gear, load or boost, so the Lambda system may be regulating things beyond idle and WOT. I think someone has noted a tach input into the Lambda when I posted on this issue, though nothing certain has emerged as to this feature having been originally engineered into the OEM system.
PostPosted: Wed Apr 21, 2010 5:24 pm    Post subject: Reply with quote
ops, forgot that it could be a s1 with a tps. The row has none. Its possible that the system automaticaly goes into open loop mode at loads, its not unusual. The fuel enrichment should also come from the wur(depending on boost), if its the same as the row car.
PostPosted: Thu Apr 22, 2010 1:06 am    Post subject: Reply with quote
Steve, sounds like your UTCIS is mapped to enrich too soon (much like factory WUR operating from boost signal only). Keep it flat 'til 4000 RPM and see what you get.
Also, SII TPS has an output signal (part throttle) that SI does not, it is likely Lambda is trying to regulate cruise emissions as well.
stevekat
PostPosted: Thu Apr 22, 2010 2:29 am    Post subject: Reply with quote
The enrichment does not seem to be boost dependent, so don't think it is coming from the UTCIS. Also does not seem to be throttle position dependent, as the rich condition seems to occur at a specific rpm, rather than boost pressure, or throttle position, at least from the basic driving tests I've done. If I put my foot down early in the rpm range, or run boost up earlier, this rich condition does not occur eariler. Seems to occur very reliably at about 3300 rpm +/-. Keep in mind I have a narrow band gauge so the degree of richness is hard to determine, but it does go of the scale at 3300 rpm and otherwise remains somewhere between the stops at most other times, except under extreme inputs. I am using the factory map, set up for their test 931.
PostPosted: Thu Apr 22, 2010 2:49 am    Post subject: Reply with quote
FWIW, on the 941, since I've installed the PLX wideband, I've been slowly tweaking my mixture. I have it idling now at 14.0...14.8. At 75% WOT and above, it goes full rich, and I mean pegged full rich, regardless of RPM. Under light load, maybe 50% WOT it runs about 11.0 or so. I am amazed at how fat the mixture was before, and yet the car still ran. Everything I've read is that the adjustment is extremely finnicky, but not so on this particular car. I've backed out the mixture by at least a quarter turn (incrementally over several sessions) since installing the wide band. I don't know how useful the narrow band is in this situation...
...oh yeah, and I don't have the narrowband O2 plugged in, so I'm running open loop ATM.
PostPosted: Thu Apr 22, 2010 5:17 am    Post subject: Reply with quote
Steve, you can also set control pressure on that unit by RPM, can't you?
stevekat
PostPosted: Thu Apr 22, 2010 7:21 am    Post subject: Reply with quote
Yes, control pressure can be set based on rpm and manifold pressure. Keep in mind less than 1 bar, is less than atmosphere in their setting I believe. So 1 bar is sea level and less is vacuum (but double check on this.) In the map I use, changes begin around around 3000 rpm +/- and stop changing about 3500 (using their 924 turbo map) however control pressure actually goes up very slightly, so that leans mixture a bit I believe. Control pressure goes down and mixture gets richer as boost gets reasonably past 1 bar. I haven't fiddled with this much as I have a narrow band gauge, and the results so far have been really good in drivability and performance from what I had before.
