CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Tue Apr 07, 2009 5:41 pm Post subject: Anyone have a 047 121 073 and 047 121 073A around? |
I need both of these... Mine are rusted to hell. Was going through the cooling system and replacing all the hoses and realized that those 2 particular tubes are rusted on the INSIDE and outside unfortunately. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Posted: Wed Jun 17, 2009 2:50 am Post subject: |
I have an extra 047 121 073 (I think). It's from my 931 UWB, and I don't believe I'll be needing it since I'm planning to fab a custom version of that cross over pipe. I need to check to see if it's the same as the NA version. If it is, do you still need it?
The other one, 047 121 073A, is apparently unique to the really early cars, so I don't have one of those. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 17, 2009 4:35 am Post subject: |
WHich numbers are you looking for? _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Jun 17, 2009 5:05 am Post subject: |
He's looking for #8 and #11 _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 17, 2009 5:14 am Post subject: |
And they are beyond cleaning up and powder coating? Every similar pipe I've seen has at least some rusty scale on the inside. _________________ Toofah King Bad
Posted: Wed Jun 17, 2009 5:17 am Post subject: |
C'mon Rasta, you've seen Corse's pix. That car looks like it was bathed in Oregonian seawater once weekly for at least half of its life.  _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 17, 2009 6:00 am Post subject: |
I have both, if I'm correct, number 11 is a big elbow, going to the radiator? I have two of each, actually, one set is still in a car. But, the others are in pretty good shape. #11 looks very clean, and #8 had some rust build-up on both ends, easily cleaned. _________________ '83 944 Track car.
Posted: Wed Jun 17, 2009 6:34 am Post subject: |
Yes, #11 connects the upper t-stat housing to the upper rad hose.
Corse, you should snag Dave's parts. I looked at the 931 and it is a different part. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 17, 2009 9:29 am Post subject: |
