16" Phone Dials
dash16
PostPosted: Wed Jul 22, 2009 12:17 am    Post subject: 16" Phone Dials Reply with quote
Where to buy them?
Which size to buy that will meet the follow criterias:
-fit into a stock 87 924S (brakes & wheelwells w/o rubbing)
-retain correct speed /w the speedometer
I have only seen availability in 16x7 fronts and 16x8 rears
anyone get pictures of these puppies in a slimbody 924?
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
emoore924
PostPosted: Wed Jul 22, 2009 2:31 am    Post subject: Reply with quote
Early offset PD's are all over the place on pelican's f/s section. or ebay... Whether your speedo is accurate will be a function of the tires you put on.
moorepower
PostPosted: Wed Jul 22, 2009 6:28 am    Post subject: Reply with quote
Here's a couple of pics of a set I used to have on my car. My tire sizes were 205/55 front and 225/50 rear, and the speedo seemed to be right. Make sure you get the late offset (52mm) from an '87 or later.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
PostPosted: Wed Jul 22, 2009 1:16 pm    Post subject: Reply with quote
You need late offset phonies from a 951, 7 and 8 inches by 16.
Try Wheelenhancement.com.
dash16
PostPosted: Fri Jul 24, 2009 10:16 pm    Post subject: Reply with quote
7 and 8 phonies won't rub? dang our cars will have mad grip running those!
and wheelenhancments sell genuine wheels? i would think you get those from the dealership or something.
STUTTGART PREVAILS
PostPosted: Fri Jul 24, 2009 11:38 pm    Post subject: Reply with quote
A number of people have put seven inch late offset wheels up front on these cars. A small spacer might be needed.
Wheelenhancement.com is a great business. They get a lot of take-offs of used genuine wheels. If you look closely, you can find a pic of Shaggy on there!
dash16
PostPosted: Fri Jul 24, 2009 11:58 pm    Post subject: Reply with quote
What size spacer do I need?
When I go ahead with the wheels upgrade, I want to do everything in one fell swoop. No fuss, no muss.
Also, what are a good set of rubbers to go with the 16" phones?
STUTTGART PREVAILS
PostPosted: Sat Jul 25, 2009 12:03 am    Post subject: Reply with quote
Talk to Dave at WE. . .he probably knows the answer to the spacer Q.
As for tires, I have been extremely happy with Avid V4s from Yokie. Perhaps 215/55 up front and 225/50 in the rear?
PostPosted: Sat Jul 25, 2009 1:01 am    Post subject: Reply with quote
Kumho ECSTAs recently won the GRM tire faceoff. I'm running them on the SH4RK and also had a set that I just sold to ivan that I was running on GEIST before I trader her for GEBLASN. I also have a set of the Yokohama's which GRM rated very high, 2nd IIRC to the Kumhos. Great thing about Kumhos is that they're one of the least expensive tires you can find.
