Posted: Wed Mar 25, 2009 3:43 am Post subject: paragon-products koni coilover kit |
http://www.paragon-products.com/Coil_Over_Kit_Koni_Cup_p/koni_cup_kit.htm
Anyone here run this EXACT kit? Is it possible without switching to alu trailing arms? $1250 seems like a steal for coilovers(even if its just the front conversion kit, but you still get koni shocks). _________________ [This Space For Rent] |
Posted: Wed Mar 25, 2009 5:27 am Post subject: |
You need aloy trailing arms in the rear for this kit _________________ 937 trackday car
Posted: Wed Mar 25, 2009 7:07 am Post subject: |
Yep, in the NEWB thread, there is a link to suspension options and it talks about the change to the shock mounts between aluminum and steel trailing arms.
Seems like an adapter bushing could be made to get around this, but I've not looked to see if this is possible at all. _________________ Stefan
Joined: 29 Jul 2001 Posts: 9066 Location: Royal Oak, MI, USA
Posted: Wed Mar 25, 2009 10:43 pm Post subject: |
If anything, I'd expect that you'd end up putting some spacers on the rear shocks (on bottom same as what they already have for the top - maybe could be ordered with extras?). _________________ Vaughan Scott
