Odometer Gear Supplier
Post new topic   Reply to topic    924Board.org Forum Index -> Links
PostPosted: Thu Aug 21, 2008 10:00 pm    Post subject: Odometer Gear Supplier Reply with quote
Has anyone tried these guys for a replacement odo gear?
http://www.odometergears.com/cable.html
PostPosted: Fri Aug 22, 2008 12:16 am    Post subject: Reply with quote
I used Speedometers Plus in LA.
PostPosted: Fri Aug 29, 2008 8:47 pm    Post subject: Reply with quote
I bought a 10 tooth gear from them. Arrived today (less than one week shipping from the US).
Great quality and a good tight fit. Jeff, the guy who makes the gears, is very helpful and responds quickly to email.
If your odo gear has split then this is where to go for a new one.
PostPosted: Tue Dec 29, 2009 6:03 am    Post subject: Reply with quote
Peter, I'm not clear, which supplier did you order from?
Do all 924/931 odometers use the 10 tooth version? Hmm...
PostPosted: Thu Jan 14, 2010 1:35 pm    Post subject: Reply with quote
Dan,
I got mine from odometergears.com (the link that I posted).
Not all 924/931s use the 10 tooth gear. I think the Carrera GTs use an 11 tooth and I have a vague feeling that some of the US cars might also use something other than 10 tooth.
Best thing would be to open the speedo up and count or you could email Jeff and see if he knows.
Post new topic   Reply to topic    924Board.org Forum Index -> Links All times are GMT + 10 Hours
