tconner
Joined: 16 Aug 2008 Posts: 10 Location: Flagstaff, AZ
Posted: Sat Aug 16, 2008 10:37 am Post subject: Pictures of clutch master cylinder mounted to firewall |
I am trying to re-mount a clutch master cylinder to the firewall and that section of firewall is so badly corroded I am replacing the whole section with a new fabricated plate. If anyone has any pictures of a clutch master cylinder mounted in the stock location on a 931 (left hand drive) it would help me tremendously to see them. A shot at the clutch master from the engine compartment would really help. Also from inside the car where the clutch pedal push rod meets the master cylinder. Thanks in advance. _________________ 1980 - 931 |
Posted: Sat Aug 16, 2008 6:52 pm Post subject: |
the slave cyl should barely fit near the wheel well...i dont have pics sorry...but mount the pedal and all the assy around there and see where it points and make sure that the lever pressing on the cyl is paralell to the cyl itself. _________________ Supercharger and EFI kits
https://www.the924.com |
924guy
Posted: Sun Aug 17, 2008 2:05 am Post subject: |
maybe these will be helpfull...
 _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Sun Aug 17, 2008 11:27 am Post subject: |
That's one item that's tough to get a good view of.
 _________________ "..it's made in Germany. You know the Germans always make good stuff."
tconner
Posted: Mon Aug 18, 2008 12:37 am Post subject: |
Thank you everyone for the help and pictures. The response on this forum is incredible. This job is going to be much eaiser now. _________________ 1980 - 931 |
Posted: Mon Aug 18, 2008 12:47 am Post subject: |
Like your horn ground repair Smoothie, same idea as mine.
Curious what the stretchy strap holds or does. We call them occy (octopus) strap down under, what are they called there? |
Posted: Mon Aug 18, 2008 1:38 am Post subject: |
Them'd be called "bungee cords" 'round these parts.
It's attached to the clutch pedal, and there to pull it back up. When the seals in the clutch master, slave or both start to go, the pedal will drop to the floor, requiring lifting with your toes, then some pumping to bring it back to life. Also on rare occasions it'll drop to the floor while the seals are still in good shape - apparently due to engine vibration, especially on hard accelleration. -So having the bungee cord there to lift the pedal for you eliminates the slightly annoying extra step of having to peel the pedal off the floor with your toe. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Tue Aug 19, 2008 12:47 am Post subject: |
Ha ha, great initiative there.
Would have thought Porsche used a spring there.
You keep proving that old dogs can learn new tricks.  |
