924turbo_sout_africa
Posted: Tue Oct 30, 2007 9:52 pm Post subject: stop's pulling at about 4000 rpm's |
My 931 was rebuilt about 4 month's ago only really started to push her around now but picked up that she whould pull in 2nd gear to about 5500 rpm's but as soon as you hit 3rd or 4th gear she will not pull over 400rpm's
I did have a 280S cam put into her which they use in the 924 challenge in South Africa just want to know will it be the timing thats not 100% or what _________________ Porsche ...where dreams are a reality
'79 924 turbo canada spec
'98 Formula Vee (M3 eater)
Time in the 931 is a dream come true !! |
Posted: Wed Oct 31, 2007 1:16 am Post subject: |
Does it start to get hot while this is happening? Sounds like its leaning out. Have you replaced the fuel filter? _________________ Toofah King Bad
dpw928
Posted: Wed Oct 31, 2007 3:47 am Post subject: |
Improper cam or ignition timing (if series 1) could also cause the drop at 4K.
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Wed Oct 31, 2007 4:13 pm Post subject: |
i will have to check on both those things hope it's not leaning out damn that will not be very good for the motor
ya it is a series 1 so will check on that one
thanks _________________ Porsche ...where dreams are a reality
