462avi
Joined: 15 Sep 2006 Posts: 149 Location: Hollister, California
Posted: Tue Apr 24, 2007 1:34 pm Post subject: passed smog |
After fixing the vacuum leak at the eec valve (see tech section) my 931 successfully passed California smog. I used the dwell meter method to adjust the mix to the proper setting, check the timing, and adjusted. Basically that was it. The car passed with flying colors as a matter of fact it was way under the max allowable limit. So to sum up, the car sat for ten years, I replaced the fuel tank because of rust, cleaned the fuel injection system and replaced all the vacuum lines and fittings. That is all it took to get it to run and pass smog. Not to shabby for a $500 car. I want to say thanks to everyone that helped out with your knowledge, I really appreciate it.
Geoff _________________ 2005 C230K
2002 grand cherokee with 4.7L |
wharris1178
Joined: 02 May 2007 Posts: 115 Location: Redding California
Posted: Mon Sep 10, 2007 9:55 am Post subject: |
I wish somebody on here would help me to get my 924 to pass smog! _________________ 2000 Cavalier Z24 imposter
84 Porsche 944 SOLD
79 Porsche 924 SOLD
Porsche, there is NO substitute. If you can afford one, lol. |
