ring931
Posted: Sat Feb 17, 2007 6:45 pm Post subject: thickness brake discs |
What is the thickness of the front rotors of a 931 with the 5-bolt setup ?
And when should they be replaced, i.e. minimum thickness ?
And the rear discs ? _________________ 931 1979 |
Posted: Sun Feb 18, 2007 10:36 am Post subject: |
According to the little Technical Specification book when new they are 20.5mm (front) and 20.0 (rear). The "Minimum Brake disk thickness after reworking" is 19.1mm (front) and 19.2 (rear). _________________ 1979 924 (Gone to a better place)
ring931
Posted: Mon Feb 19, 2007 7:38 am Post subject: |
Peter_in_AU, thanx for the info !
Does somebody know the original thickness of the brake pads ? _________________ 931 1979 |
Posted: Wed Feb 21, 2007 8:18 am Post subject: |
Info is also hopefully stamped on the rotors themselves. . . _________________ Toofah King Bad
