sway bar/control arm
pyromjm
PostPosted: Sun Jun 04, 2006 3:23 pm    Post subject: sway bar/control arm Reply with quote
any tips on re-connecting the sway bar to the control arm, for some reason im having trouble lining them up right, it seems like it should be really simple.
-Mike
1982 924 NA gray/silver with black int.
PostPosted: Sun Jun 04, 2006 11:08 pm    Post subject: Reply with quote
One source of trouble I can imagine is if you're trying to do it with one side jacked-up. -Need to have both sides at the same level.
Which bar? Early or later? Early has links at the ends and connects to "tabs" that are welded to the A-arms. Later attaches directly to the bottoms of the A-arms.
Chrenan
PostPosted: Mon Jun 05, 2006 12:51 am    Post subject: Reply with quote
Don't torque down the sway bar attachments to the body, just put the nuts on loosely, it will make it easier to rotate the bar in the bushings. Once the drop links are attached to the arms, then tighten everything.
pyromjm
PostPosted: Mon Jun 05, 2006 4:49 am    Post subject: Reply with quote
Its the late style where they attach at the bottom. i think im having trouble because i have one strut attached and the other isnt ill try removing the one
thanks guys
-mike
Vince Ponz
PostPosted: Mon Jun 05, 2006 9:06 am    Post subject: Reply with quote
Try jacking up the car until it meets the sway bar or the parts involved.
Or the wheel.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
