Paint on the rubber
bryanc
PostPosted: Sat Jul 09, 2005 2:00 pm    Post subject: Paint on the rubber Reply with quote
The PO painted the car with the minimum of masking.
He painted the rear spoiler and the rubber around the back side windows.
I would like to get these back to black (remove the paint). I can scratch the paint off with my fingernails but at about 1" every 15 minutes this could take a long time for the whole car.
Is there a quicker way to do this?
'84 944
I'd rather have a bottle in front a' me than a frontal lobotomy
Tom Waits
Vince Ponz
PostPosted: Sat Jul 09, 2005 10:54 pm    Post subject: Reply with quote
Replace the window surrounds. Remove the spoiler carefully and use paint remover or reducer available at a car paint store. As for the side ditto.
OR you could buy another spoiler.
If it makes you feel better I transported a 89 911 turbo two days ago that painted all the rubbers on the car white. I think if you lean on them they will crack and look awful. Even if you put a additive in the paint to keep it pliable.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
bryanc
PostPosted: Mon Jul 11, 2005 12:46 pm    Post subject: Reply with quote
Vince,
thanks for the tip.
Will any automotive paint remover not affect the rubber?
If not, what should I look for. I guess the paint shop would know
I guess I didn't fully explain the situation. The PO painted pretty much all the rubber white, bumper guards, windshield molding, door handles, everything.
Given this, any more advice?
'84 944
Tom Waits
Vince Ponz
PostPosted: Mon Jul 11, 2005 11:49 pm    Post subject: Reply with quote
Shoot the mother.
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Thu Jul 14, 2005 5:15 am    Post subject: Reply with quote
http://www.por15.com/uploads/files/stripper%20directions.pdf http://www.por15.com/product.asp?productid=188 wrote:
POR-15 Paint Remover/Stripper will NOT damage the following:
Glass, Duct Tape, Wood, Glue, Veneer, Rubber*, Leather**, Brass, Steel, Plaster Walls, Wicker, Aluminum, Factory Fiberglass.
POR-15 Paint Remover/Stripper WILL damage or remove the following:
Tile, Linoleum, Asphalt, Plastics, Synthetics, Sheet Rock, Paper, Wicker, Bondo & other body fillers,
* If rubber soaks in stripper for an hour or more it may temporarily lose its shape; however, if subsequently washed with water and permitted to dry it will return to original shape.
