hmmm, shiny
J1NX3D
PostPosted: Fri May 13, 2005 5:58 pm    Post subject: hmmm, shiny Reply with quote
while i'm waiting for the go bits to get done (waiting for a friend to come over and do a compression test and leakdown test), I thought i might have a try with some show bits!
i took the charge tube off with the intention to clean it but it was painted light grey and was flaking so i decided to strip it.
(these pics taken on phone- bad lighting)
http://www.flat-6.net/forum/attachment.php?attachmentid=7547
http://www.flat-6.net/forum/attachment.php?attachmentid=7549
After cleaning the stripper off, i tyhought why paint it when i could try polishing- my first attempt at polishing so i thought why not. i used about 5 scotchbrite pads on a air drill to take off the dimpled texture. i then used a fine sandpaper to smooth it out abit before polishing.
http://www.flat-6.net/forum/attachment.php?attachmentid=7552
i took the oil cap and sanded it down and painted it in high-temp silver/ aluminium.
i need to get some silvo to polish up the charge tube, should i seal in clearcoat? i would need high temp stuff wouldnt i?
http://www.flat-6.net/forum/attachment.php?attachmentid=7560
http://www.flat-6.net/forum/attachment.php?attachmentid=7561
i've taken the cam cover off to freshen up. its been painted black and is looking worse for wear. i was suprised when i removed, it looks quite fresh under there. the guy who i bought the car off on behalf of his friend (who was in England) said that the car had had a $NZ10,000 engine rebuild. As he had no receipts i took that with a grain of salt but soon after when buying a few bits from Europacific Ltd in Te Awamutu, the guy who runs the place, Steve Rasmussen said he knew the car and they'd done a lot of work on it. I wish i pressed for more info, reckon they would still have paperwork on it??
http://www.flat-6.net/forum/attachment.php?attachmentid=7565
http://www.flat-6.net/forum/attachment.php?attachmentid=7564
http://www.flat-6.net/forum/attachment.php?attachmentid=7567
http://www.flat-6.net/forum/attachment.php?attachmentid=7568
'86 944
J1NX3D
PostPosted: Fri May 13, 2005 6:02 pm    Post subject: Reply with quote
i'll take better pics of the cam, etc in daylight
'86 944
924guy
PostPosted: Fri May 13, 2005 10:49 pm    Post subject: Reply with quote
ive been doing the same thing my 931 runner... since these are rough cast, its hard to get them to a true mirror finish, lots of work... nice job!
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
J1NX3D
PostPosted: Thu May 19, 2005 5:00 pm    Post subject: Reply with quote
my friend just dropped me off from work and i showed him what i've been doing the last week. he inspected my cam lobes and followers and agrees, its very clean and minimal wear for a 25yr old car. Yay for me!
he did spot this though. the end of the cam oil squirter and broken off and fallen down the side!?!?! its just that bit thats crimped off thats broken off. how much is replacement one of these likely to set me back?
cheers!
http://www.flat-6.net/forum/attachment.php?attachmentid=7653
http://www.flat-6.net/forum/attachment.php?attachmentid=7650
http://www.flat-6.net/forum/attachment.php?attachmentid=7651
http://www.flat-6.net/forum/attachment.php?attachmentid=7652
'86 944
Raceboy
PostPosted: Thu May 19, 2005 5:56 pm    Post subject: Reply with quote
Wow , definitely don't drive until you replace the tube. Never had this kind of trouble on my cars (*knock on the wood*), the plastic elbow had been broken though.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
J1NX3D
PostPosted: Thu May 19, 2005 7:44 pm    Post subject: Reply with quote
yes, my friend explained the importance of not driving it in that condition! i wonder how long its been like that?! Im glad I took the cam cover off!
'86 944
Raceboy
PostPosted: Thu May 19, 2005 9:48 pm    Post subject: Reply with quote
Yep, not only last two lobes, where the tube doesn't exist, are starving of oil, but the other ones too, because of no oil pressure in the tube.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Fri May 20, 2005 4:01 am    Post subject: Reply with quote
Ive never had one of them brake though Ive had the intake come loose down the oil pan because I didnt use lock tight. If you want to clear those parts thated be fine just a note 'Look for high temp clear coat paint."
MunkPuppy
PostPosted: Mon Jun 20, 2005 9:13 am    Post subject: Reply with quote
I had mine break off in exactly the same spot, but thankfully I had a replacement from another head available to me. Now I just have to get another elbow, since both of mine are cracked. I believe they are available from porsche for cheap..
'80 931 FOR SALE
"It's a shame that stupidity isn't painful"
-Anton Szandor LaVey
Raceboy
PostPosted: Mon Jun 20, 2005 2:53 pm    Post subject: Reply with quote
My thought is that it's better to fabricate one (elbow) of your own from Cu metal tube: cut on 45 degrees and solder them together and apply it with flexible oil resistant silicone. More flexible and no worries, not original part though
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Tue Jun 21, 2005 2:52 pm    Post subject: Reply with quote
maybe you broke it off when taking it apart.
MunkPuppy
PostPosted: Wed Jun 22, 2005 12:26 pm    Post subject: Reply with quote
Joe if you're talking about the elbow breaking when I took the oiler tube out, then yes you would e correct. However, if your'e talking about the oiler tube itself, no, that broke entirely on its own
'80 931 FOR SALE
PostPosted: Wed Jun 22, 2005 1:15 pm    Post subject: Reply with quote
thats a bummer wonder if you drove it for awhile like that.
Seems it would of got caught up in the valve train movement.
so raceboy you say you think its ok to do away
with the elbow and just use oil resistant suilicone.
